Question about Carrier 36KCARMS Air Conditioner
Cannot get airconditioner to start model 2410a fujitzu inverter
2 years old it is like there is no power
    Scholar:
  • 68 Answers
Got a volt meter? If so follow the voltage to wear you find none, it goes to the compressor and condensor fan.
First uplug the unit from the wall and make sure the fan spins freely by hand and has no slop or up and down motion in the shaft, if so, the sleeve bearings are bad and locking the fan, either an interlock knows no fan is spinning, or it shuts down on high or low pressure switchs.
If you have voltage all the way to the compressor and condensor and nothing is happening, it could be either the fan or compressor, no voltage means a switch as stopped it, or a wire fell off, or broke off a spade.
To check the sensors, they have may be on the high side or low, make sure of no power, take the leads of each switch, and measure for continuity, if a switch is open, it is likely the switch is bad,
These are not real complicated units, but if it is 220 and you are not comfortable measuring 220 volts, get a service tech over, it ain't worth you getting hurt or worse,
But you would be suprised if you unplug the unit, and just take a good look around, something obvious may show up.
measuring the sensors with no power to the unit should not be dangerous, and if the switch it looks like a round sensor sitting on either the larger tube or smaller, pull the wires off, and they must have continuity through the switch, an ohm meter set on x1 will tell you, put the two leads of the ohm meter together, and watch the dial or display of the meter, leads together gives you a closed reading, and that is what you want, look at the tester and hold the leads apart, if you get that when placing them on the switch one on one side one on the other you know it is open, and if it has not been running, it did not just go bad, it is bad, replace it or even jumper it out temp, to see if it will go, it depends on your skill and confidence level, but never fool with hot 110 0r any voltage if you are not familiar have someone to help, or are just not comfortable,
above all if it bothers you to measure voltage DO NOT
Posted on Nov 12, 2008
How to fix a TV screen that continuously alternates between normal/light to nearly invisible/dark modes. LG Model 50LB6100-UG LED Flat screen Smart set 2 years old No movement nor adverse climate
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Dec 24, 2016 | LG Televison & Video
Lg LCD tv less than 2 yrs old has sound but no picture. What could be the problem? power supply, main board, etc??
May 18, 2016 | LG Televison & Video
Panasonic power light flashing air not cold blowing
hi there you need to see where you bhave a gas leak thats all the flashing light indicates that your gas pressure is to low to activate your compressor
Dec 09, 2013 | Panasonic Heating & Cooling
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
My Fujitzu gets: Error Mesage Condition 2 !
When you get the Error message conditon 2 ,It denotes that the internal components are HOT.
Please remove the power cord from the receptacle and allow it to cool sufficeintly.
After cooling sufficiently power it ON,If you get the Error message again then remove the power cord and contact your dealer.
Thanx
Jun 06, 2010 | Fujitsu Plasmavision 42" TV
Picture went black
The backlight inverter board may have gone out, or the power supply for the inverter may have gone out. If it is two years old, you should look at the power supply first for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. What is themodel number anyway?
Nov 12, 2009 | Televison & Video
Uneven air distribution through indoor unit
you should remove the indoor unit and send the gas to outdoor unit and remove the pipe line and start cleaning it.
Apr 10, 2009 | Heating & Cooling
Tatronic inverter problem
Tightened up battery connections
Sep 24, 2008 | Inverter Electronics - Others
Carrier 36KCARMS Air Conditioner Logo
62 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
