Question about Motorola Mobility MD41 Expandable Handset for MD400 Series
Motorola MD 400 Series - buttons will not dial number
I have the same problem as another post on this site. When attempting to dial, the keys, especially the number 3 and 6, will not dial. At times I will have to hold the button down, pressing hard, just to get the number key to dial. Any solutions will be appreciated. Steven
It worked! Thank you!
Posted on Sep 16, 2008
Kellie is right on with the keypad repair. We have 4 handsets, for about 2 years now, and are very happy with the system. However, the most used phone started giving us fits with the '3' and the 'off' buttons not working. I washed and dried my iPod nano [in the laundry by accident], and was able to take that apart and get it working again so I thought what the heck-lets have a go at this larger Motorola phone handset. I actually did this before I saw Kellie's post, and after getting most of the phone apart, I decided to do a search for hints-when it felt I was about to crack something. After getting the phone apart, and cleaning it with a Q tip and rubbing alcohol it works perfectly. I considered calling Motorola and "demandimg" replacement handsets, but I am happy to be able to fix it myself. Here is what I did:
1] remove the clip- at first you'll think this thing is frickin glued or welded on, but you actually just need to spread the "wings" on the side of the phone outward, and you'll successfully remove tabs "A" from slots "B"
2] remove battery cover and remove battery-should unclip easily
3] remove 2 screws in battery compartment
4] remove the small plate on the back of the top of the phone just abouve the clip you removed. Use a thin screwdriver and pry from the bottom of the panel, as its like a door that will want to "swing up" and out
5] remove the 2 screws you have now exposed-they are the same size and type as the 2 screws you removed from the battery compartment
6] now your nerve will be tested. You need to seperate the phone into 2 halves- a front and back. As you do this, you will think you are gonna crack either the front or back plate in half. If you can trust us, and understand that the rubber "grips" on each side of the phone are the only thing really holding the front and back together you can win this struggle. Its hard to explain, but the rubber grips on each slide have a number of slots, and the front and back halves slide into these grooves snugly and at a 90 degree angle. You could just grab one end of the rubber grip and yank away like its a zipper, but I didn't do this because I didn't want to stretch or tear the rubber and have the phone look like hell after I put it back together. There are also 3 plastic "clips" one on one side and 2 on the other, but these are nothing. Defeat the rubber grips and these 3 little clip things you won't even notice. So take your time, and eventually you should get the front and back halves of the phone apart from each other and the rubber grips.
7] remove the 2 screws holding teh circuit board to the faceplate. The circuit board should come out easily-be careful with the soldered red and black wires to the speaker. When you take circuit board out it will still be tethered to the faceplate by the speaker wires.
8] take Q-tip and rubing alcohol and wipe all copper contacts and backs of rubber buttons like a wild man [wild woman]
9] let dry [a few minutes], put back together in reverse of way you took it apart- little stubby antenna will possibly fall out at some point, just set it back in when you put two halves back together, then enjoy Utopia as your phone will now work like it did when you first took it out of its stupid box !!!! Any questions? post a comment and I will try to answer them good luck, its really pretty easy ! If sexy Kellie can do it so can you !
Posted on Oct 23, 2007
Follow the link http://www.amazon.com/gp/product/customer-reviews/B0000AKMKY/ref=cm_cr_dp_2_1/103-7434608-9035822?ie=UTF8&customer-reviews.sort%5Fby=-SubmissionDate&n=172282 scroll thru the customer reviews, until you get to "fixing keypad problem". It works exactly how he/she describes it. When I was completed, and was trying to get the battery plate back on, my finger touched the on button and the phone turned on! I was in amazement, due to the fact I had to use the "handsfree" button to answer calls for the past few months. I have heard for a few years now to stay away from Motorola Cell phones (they are junk), my guess is the same for their home phones. I think it is rediculous to have to do this to my phones.
Posted on Oct 01, 2007
The keypad has some kind of defect. I think that over time the silicone mold-release agent from the keypad buttons works its way into the electrical contacts. You can clean off the contacts with rubbing alcohol and a cotton swab. Here are instructions: http://www.amazon.com/gp/product/customer-reviews/B0000AKMKY/ref=cm_cr_dp_2_1/103-7434608-9035822?ie=UTF8&customer-reviews.sort%5Fby=-SubmissionDate&n=172282
Posted on Mar 29, 2007
Feature Button Not Working
Feature, Redial, press button to program, dial 1, dial the extension number, Feature to write and exit. ONLY IF the buttons are programmed as feature buttons, they may be just dead buttons, useless until they are assigned in system programming as feature buttons.
Nov 22, 2013 | NEC Lands Phones
Panasonic KX-T7730 Corded Phone programmed speed dial numbers not working. will not dial numbers programmed
When the system is installed, you need to make sure that only the lines equipped are in the access plan (program 400 in a TA series box). When you go to the intercom on a phone and dial "9" you should get an outside line every time. If that works, system and personal speed dials include that access code as part of the number. eg my test number is 914197845522 9+1+10 digits.
Carl
Apr 01, 2011 | Panasonic KX-T7730 Corded Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
How do iset up speed dial
Do these:
  1. Press Menu Button.
  2. Select Settings.
  3. Select Initial Setup.
  4. Select 1-Touch Dial.
  5. Assign specific numbers with the keys 1-9.
Oct 18, 2009 | Motorola Mobility RAZR V3
How can I make 3-way calling from my Motorola Q Cell
1) Dial the 1st number 2) Once connected, press the Send/Call button 3) Dial the 2nd number 4) Press the Send/Call button again 5) Once connected to the second call, press the Send/Call button again 6) The 3-way is connected.
Apr 13, 2009 | Motorola Cell Phones
I am trying to set up speed dial for numbers 2 thru 9 & I get an error message that the Location is in use. If I were to hold a key in attempt to dial, it tells me the speed dial # is empty??? Any...
Depending on your phone version, you will be able to access speed dials in the contacts menu of your phone. If it is anything like mine when you press the menu button contacts is the first one up. Speed dials is the bottom one for my version. Once you select the speed dials you will see empty slots for contacts select one of those and it should take you to your contact list so you can select a contact for that speed dial location.
Apr 07, 2009 | Motorola Mobility RAZR V3
Set speed dial
This may or may not work as my manuals are for the 9xx series but not the 950. Press PROGRAM
to erase press PAUSE and either the BUTTON or LOWER BUTTON (2 keys).
To store a new number, PROGRAM then dial the number you want saved (or press REDIAL) then the BUTTON or (LOWER BUTTON).
I'm guessing this will work, since the other models seem to program the same way.
Carl
Feb 27, 2009 | AT&T 950 Corded Phone
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Open Questions:
Motorola Mobility MD41 Expandable Handset for MD400 Series Logo
694 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Harrie
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
