Question about LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White
Washing Machine Stopped Flashed ''LE''
L G Model WD1019BD
    Scholar:
  • 68 Answers
First remove all clothes and look for anything like a wash cloth that may have become stuck, then remove the cord from the wall socket for at least 30 minutes to be safe, and try this again if doesnt work the first time, two, move the drum by hand, close the door, and see if fires up, if so run a 20 minute custom light duty cycle, third replace the drum positioning sensor, 6501KW2001A.
It can be bought on line for between 25 and 40 bucks
Will
Posted on Nov 12, 2008
LG WM2350HNC Front Load Washing machine displays LE error, I have tried cleaning it and flushing the drain hose out and the filter., still will not work... Tub tries to spin but can't... It is only...
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. What is the model number listed on the machine? The number posted was for a range.
Nov 14, 2012 | Washing Machines
My washing machine stopped spinning and displays LE on the digital pad.help me out
dont know what brand you have mostly LG. LE error is hall sensor is bad
Oct 24, 2010 | Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
Oct 30, 2007 | LG WM-1832C Front Load Washer
LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
136 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
