Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Battery replacement now ca't find satellite Garmin c320
I recently replaced the battery in my Garmin street pilot c320. Battery works fine, just can't locate a satellite any more. Has this just become a paper weight.... Any hopes for to correct this?
  • Anonymous Feb 21, 2009
    I have the same exact issue, I replaced my battery becuse the unit would not stay powered on. I know the antnna in installed correctly and the connections on all the wires are good, It will not locate the satellites, once in a while it will locate them but only with one bar of reception and the device continously re-calculates because it cannot figure out exactly where I am. I tried switching the GPS mode and reseting the device, no luck. My new battery had an extra wire, it was green, I assume it was an un-neccesary ground wire because the factory battery did not have it, I tried using the device with the wire connected and with the wire cut, no difference. My device appears to be a paperweight, furthermore I just purchased updated maps so I am out an additional $69.00, ugh. Any suggestions out there?
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Posted on Nov 25, 2008
Can i use garmin C320 street pilot in italy
Most stock units are equipped with a US & Canada map if purchased in the US. Yes, the unit will work in Italy but you will need to add a Europe Map on an SD card, as the internal memory may not be large enough to hold both maps.
Feb 17, 2014 | Garmin StreetPilot C320 GPS Receiver
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Screen says low battery, then goes blank. can I get a new battery?
Yes, you can replace the battery. Please view video at link; http://www.videojug.com/film/how-to-replace-your-garmin-street-pilot-c330-battery-2
And also see link to purchase battery.
http://www.newpower99.com/Battery_for_Garmin_StreetPilot_c330_p/garmin%20streetpilot%20c330.htm
Please let me know if it helps.
Thanks
Apr 26, 2010 | Garmin StreetPilot C330 GPS Receiver
Our Garmin Street Pilot will not charge. Do the
The batteries DO die after a time. They are not designed to be replaced by the user. If you believe your battery has died, you should contact Garmin.
Jan 05, 2010 | Garmin StreetPilot C330 GPS Receiver
Need battery for street pilot c330
THis battery will work in your C330 Garmin. I have had it in my unit for 3 years now without any issues.
http://www.etronicspal.com/132805.html
Just open the unit and splice the wires, and use some electrical tape. Good as new.
Jul 18, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot c330
Pull the face off try to reset it, if it will not reset, or work in the car or the house, the battery needs swapping out,
Garmin $100
Regards
Jun 21, 2009 | Garmin StreetPilot C330 GPS Receiver
More than likely when you reinstalled the gps receiver (the board with the wires connected to it) at the top of the receiver you did not position it properly. If it is not positioned properly it will not receive a satellite signal
May 06, 2009 | Garmin StreetPilot C320 (010-00401-00) GPS...
Garmin Street Pilot III map source data card not accessible
Garmin has issues with the newer (ROHS Compliant) cards, so If you recently bought this card get a replacement from garmin.
I had these issues too with a 256 MB, garmin replace the card with 2 128MB cards, worked fine after that.
Mar 26, 2008 | Garmin Streetpilot ColorMap GPS Receiver
GPS Logo
488 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
