Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Gas oven smell
My new gas oven smells funky when in use, like a factory coating or something is burning off. We have had it for six months and it still smells. It is not a natural gas smell. We have to open window while using the oven. Please help, its driving me crazy. We started getting the smell the first time it was used for baking. After a while the smell dissapated. But, now when we use the broiler, the smell is even worse. It does smell like some kind of coating or plastic burning off. It is very acrid and irritates the lungs. It somehow smells like teflon when a teflon pan has been on the the stove at too high a setting and starts burning.
  • jivanrob Dec 15, 2008
    I have the same problem but it isn't the temp. that is accurate. after the oven has got to temperature, the smell goes away. but while it is heating up, you can see the smoke coming up from it.
  • gmalbe May 21, 2009
    Same thing, only I have been hesitant to actually cook anything in there yet... I feel like something from the manufacturing process is trying to burn off, but I've run it at 500degrees for an hour and the smell seems to only intensify. I can see actual smoke in the room.
    Scholar:
  • 68 Answers
Have you checked the temperature with a hand held or stand alone thermometer? First thing I would do is get a cheap oven thermostat, set the oven to 200 and make sure the oven is not being controlled.
This smell, does it sour the flavor of whatever you are baking, broiling whatever?
Sounds to me the oven might be over temperature, if it checks out against another thermostat is there any breakin procedures in your manual or cd?
Check that out, next have you called the oem?
cALL EM AND TELL THEM WHAT YOU ARE EXPERIENCING, MAYBE THEY HAVE A BAD COATING,
If that goes no where, get a mailing address, ,get a frozen pancake or waffle if it is sticking to the food, cook it, wrap it hot in plastic rap then aluminum foil and mail it to them.
Once they take a wiff of it you will get some relief,
I am concerned you might have some kind gas that could prove to be unhealthy, so get this dealt with, the three suggestions above should get you an answer.
Will
Posted on Nov 12, 2008
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
I smell something burning when the oven is on...not as "eggy" as gas but I have a pregnant wife and I'm scared to use this thing.Is it just a new oven smell?
I would have a service call made and have the service technician check for correct installation
Smells ( that cannot be attributed to burnt food, gas ) should be investigated as they are the early warning signs of a problem
at least you will have peace of mind and may be advised as to a product that can be used to remove the smell
Sep 01, 2015 | Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Burning smell from underneath the bottom oven plate
Something spilled into the area where the flame is Those big gaps in the bottom plate is how the heat gets into the oven from the burner . Try letting the oven burn off whatever spilled in it
Jan 04, 2014 | Samsung FX510BGS Gas Ranges
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
I have fitted a new element to my creda fan oven but when i put the oven on it smelled of burning is this normal
You can expect it to smell for a while, as it is a protective coating on the element.
Run it at a high temp for a few minutes with the door open if possible, this should get rid of the smell.
Hope this helps.
Dec 15, 2009 | Ovens
Burning plastic smell
Hi, Sounds like something is wrong. Is this a gas or electric oven? Did you have to change settings from natural gas to lp?
Please let me know, I would like to try and help you.
Vic
May 27, 2009 | Kitchen Ranges
Vapor Smell
DO NOT OPERATE THE OVEN UNTIL YOU GET SOMEONE TO CHECK IT THAT IS FAMILIAR WITH A GAS STOVE!!!
It is very possible that the oven is not burning clean and this will release carbon monixide into your home. This could be very, very dangerous.
If you have just purchased the oven, then it may need to be set up for the type of gas you are using.
If it is not new, then it may have some problem with the air intake to the burner.
It could also be something harmless such as a spill that is burning off, but if you are not sure what it is, please take the safe route and do not use the oven.
This is not a problem that can easily and safely be determined from an internet website. A competent gas repairman needs to look at it if it is burning your eyes.
I understand this answer may not qualify as a fixya rating for you, but I am more interested in your safety than my rating when it comes to a possible dangerous problem.
Please be safe.
Thanks/Mike
Dec 01, 2007 | Ovens
Gas oven smell
I have the same issue. I live in an apartment, and I had maintenance come by to check it out. They say that it is carbon (white, ashy) built up around the burners from where the gas is burning. They clean it, but then it comes back. I'm wondering what else it can be because I feel like death every time we use the oven. And I know, I shouldn't use it! Well, I like to cook, and I'm stuck in this crappy place until the end of my lease. I don't know what to do either. If my maintenance actually figures out the problem, I'll let you know.
Mar 18, 2007 | Tappan TGF657 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
1,591 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
