Question about Sony P6-120MP 8mm Tape
Tape i have a sony camcorder and every time i turn it on it tells me to reinsert the tape.
  • 88 Answers
Fine you insert another one good tape and try once more
if the problem presets check the tape door switch.
if not ok .open the tape mechanisam andcheck for any foriegn meterials block in between tape door switch or else blocking near the Rec/play head.
wish you all the best.
Posted on Nov 21, 2008
    Scholar:
  • 61 Answers
Try this:
1. make sure the tape is not loose - turn one end to tighten
2. make sure the head is clean - try a qtip or slightly damp swap long enough to reach and clean the head (silver drum but please be extra careful not to use to much force there is a litte haed that reads the tape and if you get any strands caught on here it will be hard to get out) the head will spin but clean and hold as much as possible because the head is harder to clean while spinning and the head is in between that has a very small slot to see it but it is close to the gapped seem of the haed
3. if you can fwd and rewind tape
4. make sure nothing is stuck in like and torn tape pieces
Posted on Nov 12, 2008
I have a sony dig 8 trv340 and am receiving an error code of c31:42 what does this mean?
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
Oct 23, 2010 | Sony Video Cameras
Cannot load tape
No problem the camera is telling you to use tape head cleaner before trying to record more movies that all.
Jul 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
When I insert a tape, the screen flashes "reinsert cassette".
Hit your camera several times with a flat hand (bottom, tape side). Its strange but my problem was solved. On internet I found maybe 10 or 15 other people who did the same.  Really works!
Apr 05, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony camcorder
Dec 30, 2007 | Sony Handycam CCD-TRV308 Camcorder
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
good luck
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
SONY CCD-TRV138 8MM CAMCORDER
CCD-TRV138 Attempted to record or play. Not operating.
Dec 20, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam DCR-IP7E Micro MV Digital Camcord
Nov 03, 2007 | Sony Handycam DCR-TRV250E Digital...
"reinsert tape" message
I can't believe it. I tried hitting the camcorder on the battery side, directly on the battery with the palm of my hand and it worked for about 5 seconds. THEN I hit it against a wood table on the battery side and it is now working. I guess my first hit with the palm was not hard enough.
Jul 25, 2006 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony P6-120MP 8mm Tape Logo
113 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
