Dear Sir/Madam,
Click this link for manual. Refer Manual From page nos. 54 to 60. It will be clearly defined and how to solve this problem.
http://www.olympusamerica.com/files/DS3300ManEN.pdf
Thanks
Good Luck
Disconnect Footswitch from computer
if using a straight USB connection, delete all instances of previus installation.
reboot & reconnect footswitch (swap cables if not detected)
Check if the drivers are compatible with vista
Hi!!!
if you want to get the picture!!
try to use card reader if you have
it can detect the picture
store in your memory card
hi!!
try to figure out if the device is compatible with vista!!
or try to update first
here is the link
http://www.olympusamerica.com/cpg_sectio...
or replaced the usb cord if you have a extra
or use card reader
Well first thing to try in getting the software installed is to right click on the install file and select run as administrator, the setup should work better.
This is just a initial idea so use the add a comment function to tell me more about the problem
Thanks,
Ekse
Ekse,
Thanks for trying to help me. I just bought this computer and found out after the fact that the programs that I need for class which are WordPerfect X3 and my transcription equipment. Now, the Olympus DDS Transcription Module loaded fine, but after I download my dictation and try to play it back with my Olympus Footpedal, I can hear the dictation comming through my earphones, but it isn't being controlled by the Footpedal.... The footswitch shows up on my control panel, but its not installed.
The other folks in my class do not have Vista and it loaded fine without software....it did not come with software....Also, my teacher gave me a WordPerfect 12 disc to install to replace the X3.....
She told me my equipment and software should work with my computer....and I don't know enough about it to disagree with her...can you help me.
I tried your suggestion, but the install file never came up...or where do I find it....does it not pop up on its own....Thanks again
