Question about Whirlpool ET9FHTXMQ Top Freezer Refrigerator
Motor noise When the motor turns off it makes a loud clunk and screach noise. We have cleaned the coils, and tried to relevel it but the noise still persists.
  • 2 more comments
  • Paul Movall Nov 15, 2006
    Thanks for the suggestion. I took the back panel off and did find that the compressor is making the noise. It shakes quite a bit when it turns off, thereby making the noise. I was also able to recreate just by shaking it by hand (pushing on the side of it while still mounted and letting go quickly). I was not able to tighten any of the mounting bolts. Are we on the last leg of the compressor or is there something else I can try? Thanks in advance for any suggestions!
  • Paul Movall Nov 16, 2006
    Thanks for responding. I'll try to provide more details.
    The noise isn't coming from any of the tubes, it is from inside the compressor. When it makes the noise, it shakes ALOT. Other times it will shut off gracefully and not shake. I was able to move the compressor with my hand probably more than 1/4" - is that typical?
    I could only see three of the mounting bolts and there didn't appear to be anything wrong with the bolts or the mounts. I could not see the fourth one as it is behind the compressor, but I did not feel anything unusual compared to the others. I was unable to turn any of the bolts more than a small fraction.
    If I wanted to do something with additional insulation, where would I place it? Or should I just be looking to replace the mounts? Thanks in advance for your expertise!
  • Anonymous Jan 25, 2009
    Clanging during shutoff was noticed for awhile, now noice is constant when running-probably motor is going bad-right?
  • Anonymous Mar 23, 2014
    Whenswitching on boiler to top solar psnels heated water dreadful noises come from loft but stop when boiler switched off
  • 237 Answers
You can remove the lower back cover panel and visually see the compressor and fan. Check the mounting bolts on the compressor to see if they are loose allowing the compressor to bounce around in there. You can also "stall" the fan with a wash cloth to stop the blade from turning (it's OK just try not to bend the blades). That will eliminate the fan squeaking as it coasts down to a stop. Better to stuff a wash cloth in while the fan isn't running. Turn the t-stat up to colder to force a run condition for a minute or two then turn the t-stat down and watch the compressor and listen for those sounds again.
Posted on Nov 11, 2006
  • Marc Wilson
    Marc Wilson Nov 15, 2006
    The compressor is probably fine and not on it's last legs. The mounting rubber that allows the flexing may be torn somewhere letting the compressor move more than it typically should. Can you tell where the tubes, etc. are hitting and causing the noise? Some cork insulation sheet makes a good material to isolate things from rubbing, etc.
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 14, 2011 | Kenmore 659 Electric Dryer
My 10yr old model#690 freezer is having trouble maintaining temp and when the compressor shuts off it makes a loud clunk noise. I have check to see that fan is running and have turned unit off for about...
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. Have you tried cleaning the coils? let me know.
Mar 06, 2011 | Sub-Zero 690 Side by Side Refrigerator
Amana ARB8057CSR Bottom Freezer Refrigerator, Intermittent Quick Loud Noises Appliance history: Purch. 12/03. Replaced PTC relay 12/08. Water filter last replaced 3/10 (2-person household). Problem:...
No-one posted a solution. I contacted the original solution poster who was very helpful.I hope this helps someone else better understand their refrigerator problem and get on the right track. Staffgage.
Tweezb wrote:
"you are right that cleaning under your refrig wont get rid of a "compressor knocking" sound. what it might do is to lower the amount of heat from the condenser coils and thus cause less pressure and stress on the compressor making it run easier and less likely to bang or knock when shutting off.
if your coils were very plugged with lint and you have cleaned them, that will help but it wont "fix" the problem.
inside the compressor is a motor and a pump, the motor is supported by 3 springs and they can stretch or break causing the motor to hit one side of the black outer can and cause the noise.
that may be too technical, but its not something that can be repaired without replacing the compressor, at a cost of 700-800 bucks. most would not pay this as its not worth putting that amount of money into an older refrig."
"think that you are hearing either a freon related sound or even just the sounds of the unit going thru defrost.
how often do you hear the noise? just maybe once a day or is it everytime the unit shuts off?
either way i would rule out the ice maker and water system as when the "shut off arm" is up then it is off and wont make any noise, or ice.
keep the i/m arm up and then listen for the next day or two and try to narrow down when it makes the noise and frequency you hear it and then get back to me.
it may not even be a problem, just normal operating sounds that cant be changed."
Oct 20, 2010 | Refrigerators
Start pool up this year pump is louder makng whine noise, works fine and it is not getting hot Is the pump going
loud screaching noise??? sounds like bearing failure. this most common failure of pool motors. YOu can try to replace the bearings or replace the motor.
May 22, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Need blower wheel replaCDED?
If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
May 07, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool ET9FHTXMQ Top Freezer Refrigerator Logo
772 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
