Question about Logitech X-530 Computer Speakers
No Sound! one day i have it the next day i dont. double checked power supply and all wires. still no sound what els should i do????
    Genius:
  • 1,124 Answers
Check on Control Panel >> Sounds
Posted on Nov 12, 2008
No sound on computer
Is the power cord plugged in, is the wire in the right port? (GREEN on most pc's) and last check the computers sound settings, double click the speaker icon next to the clock and make sure it's not muted.
L8ers
Sep 12, 2010 | Computers & Internet
No sound, Tried unplugging system for several days no help. Checked all wiring to speakers, looks ok. made sure speaker switch in correct position.
if you have a sound card you might need to reinstall the driver. if you dont have one double check the sound settings on the computer. maybe the speakers are not active
Jun 27, 2010 | Sherwood R-925
I had my computer speakers since 2005 i had windows xp and i just got my computer fix and now i vista home premium and i went too the media player and i played some music and next time i played it didnt...
Is your pc volume turned up, if so you say you had your pc fixed did they do an upgrade or anything like that if so then they may have altered your sound settings or not even installed the sound drivers.
first check that the sound is on and the speakers are plugged into the correct socketon the pc,
If this is ok then check to make sure your drivers are nstalled and using the sound card you have installed you will have to goto control panel then double click on the sound button check to make sure making sure your speakers are enabled, And check your properties you shouls see your sound card listed in the properties section.
Jun 16, 2010 | Audio Players & Recorders
I can't hear the sound
First troubleshooting steps, double check your speakers, wires to speakers and power. Next if it is onboard audio check bios with peripheral devices and see if it is disabled. Third device manager is your next stop see if sound card is installed and does not have any errors or exclamation points. If at this point the sound card is installed and looks as if running fine but there is no sound, the next step is double clicking on the speaker in the bottom right, go to options then properties and check mark all the other sound device volume controls and also check the volume control you can find in control panel.
Oct 29, 2009 | Dell OptiPlex GX270 PC Desktop
No sound on my computer speakers . Connected properly and had sound up to a few days ago
Make sure the sound on your computer is on. Check for the speaker shaped icon in your system tray (near the clock) and make sure there is not an "X" over the speaker. If there is, double click and be sure to un-check the box.
Oct 22, 2009 | ViewSonic VA2026w Monitor
No sound coming from sub woofers amp is connected and powered properly,all connections are correct,i have checked all connections to head unit,to battery i have disconnected and re connected all...
check your amp fuse also any car fuses, then check inside the sub box at the connections as they dont come connected when you buy it, try that 1st
Jul 11, 2009 | Car Audio & Video
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
I just brought mine to the shop for the same reason. I thought it was something big but it was just a bad fuse. It wasn't blown so when i checked it, I didn't think anything of. If you're using an AGU fuse, try and remove the fuse and touch the two ends of your power wire together and if it's the fuse it should cut on
Mar 18, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Noise from woofer
Double check all of your cables, but it sounds like the power supply may have died. If the sound is like a mains hum, then the power supply will need to be replaced. Is it an internal or external one ? If it's internal, are there any fuses accessible ?
Sounds obvious, but double check the speakers are all correctly plugged in, by removing and re-inserting them. Check the volume controls and and other switches too. Try plugging headphones into the audio outputs to confirm their is actually a signal present, as the speakers may be fine, but the source may be faulty or its configuration changed.
Nov 20, 2007 | Car Audio & Video
NO Sound At All
Checa con una bocina externa las salidas de audio del aparato,si funciona las bocinas del carro son amplificadas.Y si no funciona el amplificador de audio del estereo esta quemado.
Oct 04, 2007 | Panasonic CQ-DF903U CD Player
My Television Turns on, but there is no sound or picture, Is there a Resent Button?
There isn't any reset button. All you have to do is to take out the power source. Anyway, double check the wires... are you sure all are well connected?
Dec 19, 2005 | Hitachi 55FX20B 55" Rear Projection...
Logitech X-530 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
