Question about APC Back-UPS Office 500VA (BF500) UPS System
Surge protectors I have a surge protector that only 3 of the 6 outlets work. Why is this? Also, do surge protectors need to be charged before usage?
  • 348 Answers
No no need to charge there may loose contact between power cord and surge protecter or internal loose contact between sockets that can be removed
Posted on Nov 12, 2008
Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Oct 25, 2012 | Televison & Video
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
My Kenmore elite microwave is plugged into a surge protector and keep tripping the surge protector. I cannot use the microwave for more then a minute before it trips. Can you help
Your microwave is pulling more amps than the surge protector can handle. Remove the surge protector from the circuit and plug oven into wall outlet. Preferrably a GFCI circuit. Or you could puchase a surge protector with a higher amp tolerance.
Sep 04, 2011 | Microwave Ovens
My hp printer 6110 officejet all in one keep giving message scanner failure when i want to print something
Please make sure that the printer is connected to a wall outlet and not to a surge protector because surge protector distributes the total electric supply equally to each and every device connected to that surge protector. Printer might work and might not with a surge protector but it will always work fine with a wall outlet till the hardware of the printer and power chord, adapter are working fine.
some times scanner failure error comes if it is not getting enough power supply.So if it is connected to a surge protector then I will suggest you to disconnect it and connect it directly to a wall outlet.
Now scan or copy any document and see if something happens.
If not the do check while you press scan or copy button the scanner light is moving or not?
If scanner light is not moving then do a hard re-set.
Hard Re-Set :
- disconnect power chord from the back of the printer and then from wall outlet or surge protector.
- wait for 40 secondsand then connect the power adapter to wall outlet and then to the back of the printer. The try to scan or copy....still not working then check if the scanner bulb is glowing or not?
If scanner bulb is not glowing and if you dont hear any noise while you press scan or copy...then printer hardware has gone bad and you need to replace the printer
Feb 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Taco timers and Surge Protectors
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Sep 06, 2009 | Plumbing
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Surge protector shuts off while playing PS3
swap to another surge protector. if it still does it, it is a power surge at the outlet, if it does not, the Surge Proctector has worn out. have someone with the appropriate knowlege have a look at the outlet as well. older outlets especially tend to wear to the point where the plug literally falls out of the wall.
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Nov 30, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Dynex Te685avr backup battery doesnt work
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at:
Jun 26, 2008 | Dynex (TE685AVR) UPS System
APC Back-UPS Office 500VA (BF500) UPS System Logo
230 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
