Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Feedback noise from mixer
I have a pioneer djm-600 and I'm getting feedback noise from it when Iattempt to record. I've tried both stereo and phono outputs and thesame noise occurs. I have a aluminum plated copper wire i'm trying toground it with, but I dont have anything/know what to ground it to? andI dont know if that will solve the problem but I've asked some of myfriends and they seem to think that's it
  • cpomeroy18 Dec 19, 2008
    I'm recording onto a laptop, and i figured out that when i unplug the power cord to the computer, the buzz/humm noise totally goes away. But my battery is shot and I only get like 15 or so minutes of use out of it on a full charge... so besides getting a new battery, and thoughts on what i can do? thanks!
  • 515 Answers
Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
    TERMiNAL OPTiC Dec 19, 2008
    Power cords are always a source of ground issues when they have alot of current running through it, are not properly shielded (like generic power cords), or if your running your power cords right next to your audio lines. Try and keep them separated, or shielded from each other.
    I would suggest replacing your power supply, with an original developed for your computer. If it is no longer made, then I would suggest getting a high quality power supply.
    FYI, the transformer on laptop power supplies (the big black box on the line), emits some powerful signals, because this is where the power is transformed from your laptop and converted to be connected to the wall. Otherwise, it would damage your laptop. This transformer, is usually inside on regular PC's, but because of it's size, it would require a large housing on the laptop... not making it as portable or compact as one would like.
    A HUM ELIMINATOR will also help with minimizing any ground issues on the line. Hope this helps.
    - OPTiC
    A DJ Pro Audio Co.
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Playing a ipod on a djm-500
Use a male Twin Phono to 3.5mm stereo jack plug lead. The two phono connectors need to be male, so that they can plug into the red & white line sockets at the back of the DJM 500.
Are available in any audio products store.
Jan 24, 2009 | Pioneer DJm500 Professional DJ Mixer...
DJM 500 & 2 1200mkIIs -- Very Low Sound With Multiple Speaker Sys
are you sure you have your tt's plugged into the phono line with the master booth knob turned up? Check the mixer too cuz the techs should be square.
Jan 15, 2009 | Pioneer DJm500 Professional DJ Mixer...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
I have the same problem, One day I open the djm-600 for replace the jack whole (easy), then of this when i close the mixer my pioneer died, but when I push the power button I can listen a little sound like ¿voltage running? Please Help !!!
pd: sorry for my bad english
Nov 17, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Help with set up
connect your gemini phono out to -------- pioneer phono in.
Jul 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
1,301 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
