Question about RCA Televison & Video
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is supposed to be a smart antenna and if it is not. What store sells this smart antenna.
  • 61 Answers
Try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Posted on Nov 12, 2008
Tried connecting an interior antenna from radion shack to L32HD31R just to get a couple channels without having to get cable.girl at the store said to check manual to see if tv has converter box built...
If you got some white noise then your TV is getting some sort of signal it is just weak.
The best thing to try would be a Signal booster. If that doesn't work then you would need to look into upgrading your aerial.
Apr 27, 2011 | RCA L32HD31 32 in. LCD HDTV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Cannot connect the coverter box
When you have your converter box hooked directly with coax to your tv, is your antenna then plugged into your converter box in the "antenna in" port? What do you mean by it doesn't work? Does it say no signal? If so, you just need a stronger antenna. If not, you may have a defective box, bring it back to the place you got it and see if they can help.
Dec 27, 2008 | Symphonic ST420FF 20" TV
RCA DTA800B1 converter box - Works great for 15 min. then quits.
I would suggest to return it because it should work as intended without dropping the signal.
It would be a good idea to add a signal booster to keep a good signal strength.
Mar 31, 2017 | Televison & Video
Installed Insignia box, keep getting No Signal
You need a stronger antenna. Many of the VHF channels moved over to UHF thus if your current antenna doesn't pick up UHF, you will not pick up those channels.
Dec 11, 2008 | Insignia Digital-to-Analog Converter for...
I recently bought a converter box DTA800 to go with my sony tv Triniton mod.KV-20FV300. It doesn't seem to work; programing, set-up. Please advise.
Ah, the problem is likely your antenna. Make sure everything is properly hooked up, and that your TV is on and turned to either channel 3 or 4 (whichever the unit requires, or you can try both and see which works) then turn the converter on, and check the manual that came with it for a way to check for your antenna's signal strength.
If your signal is good, then use the menu button on the remote and look for an "autoscan" feature, or "autoprogramming", something along those lines, and let the unit look for channels for you (mine requires this before you can use it, not that it matters because my antenna signal is weak). From there you can access the channels manually.
Hope this helps.
Jun 26, 2008 | RCA Televison & Video
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
168 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
