Question about Gateway ML3706 Notebook
Motherboard replacement hey do you know were i can get a gateway ml3706's motherboard replacement?
My gateway Ml3706 laptop shuts off after 5-10 min of using. they keyboard gets hot and the fan does not click in. i cleaned the computer of dust but im not sure if i need to pull the fan out and clean it...
Random reboots are usually an overheating problem. First step is to look into the vents and see if they are clear of dust, fuzz, animal hair etc.
If they are clear you will need to access the fan/heatsink. The heatsink can accumulate dust depending on the design. If the fan sounds "abnormally loud" it could have bad bearings from dust and dirt and may need to be replaced.
Most laptops come with some way to monitor the temp, usually in the bios. Occasionally they come with a utility. You can use that to check the heat levels.
Jun 28, 2011 | Gateway ML3706 Notebook
On my gateway laptop every time i seem to watch a movie or a video on youtube or just a normal video my computer screen goes black and then i get an error message saying display driver r300 has stopped...
There is a problem with your driver. Try downloading it and reinstalling it. If that doesnt help then you most likely have a problem with your video processor.
Mar 23, 2011 | Gateway ML3706 Notebook
Gateway ML3706 no recognized hp deskjet d4360 say unknown device in usb. I can not add the printer
Try and go to printer and fax setup the add printer maunally it will ask that do you have driver for your pinter then click yes.........
Oct 24, 2009 | Gateway ML3706 Notebook
I need to know how to get the bottom off my laptop so i can get to the power button and fix the sensor underneat it. i removed all the screws on the bottom yet it wont come off. myl aptop is a gateway...
the bottom doesn't come off......you have to remove the cover on the screen hinge and remove the keyboard and monitor to isolate the "bottom" of the unit. After you have removed the panel on the hinge, you can unscrew the keyboard and detach the screen. At this point the bottom can be removed by taking off the main boards and other connected components.
Good Luck and please rate this post
Oct 04, 2009 | Gateway ML3706 Notebook
My gateway laptop will not turn on when you push power button.
If you power it on and get the light it means either two things:
1. It needs a minimal charge on the battery to power. ( havent seen this since the old Compaq/Apple stuff ) or
2. The motherboard is fried. ( Just diagnosed a HPDV6000r special edition with this beautiful computer, dead motherboard ).
What is the warranty like:
NOTE TO ALL STUDENTS: Buy New laptops in November, so the warranty comes up in October, after you know you need more computer or repairs!
Oct 03, 2009 | Gateway ML3706 Notebook
My left speaker on my gateway ML3706 laptop just stoped working
If you get sound from both sides of the headphones when you plug it into the same jack the speakers normally plug into all you need to do is replace the speakers. If you mean you plug the headphones into the cd drive that's nothing special. You could have a bad sound card, bad connection in the jack, or bad speakers.
Jun 20, 2009 | Gateway Computers & Internet
Gateway M-6750 Motherboard Power Short, Little Clips
Had the same issue. Clip fell off, moved around, hit the motherboard and it fried. I hope there is a class action lawsuit against gateway
Replacement motherboard $400, new Lappy $600.
Jun 09, 2009 | Gateway M-6750 Notebook
Gateway Ml3706 wont boot up BOOTMRG missing . runs on vista
Are you using Windows Vista? You can fix this problem bt using your installation dvd. After the first couple of scrrens, you will get an option to REPAIR the installation. You should get a functioning system after that.
May 19, 2009 | Gateway ML3706 Notebook
Gateway ML3706 Notebook Logo
57 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
