Question about Sony PlayStation Portable (PSP) Console
The computer is on a secured wireless network i was just on my psp with it and apparently the ip address was droped from my psp along with all the other info and i cant seem to get it back on i get to the ip on the computer witch is online and the ip address doesnt fit in the space provided on the place for psp ip so wht do i do
  • 25 Answers
Set your settings to automatically obtain IP address
Posted on Nov 15, 2008
HOW DO I GET THE INTERNET USING MY PSP?
You need to connect it to a wireless network, from the home screen go along to settings, down to network settings, choose a mode, (Infrastructure should work fine) New connection, Scan, (here you should see your SSID and signal strenght) choose security type that your wireless network has. enter any security details such as WEP key. Choose Easy for address Setting, choose a connection name. (Home) Save it and then test the connection, if it fails it should show you where it fails along the line.
Hope this helps
May 05, 2011 | Sony PlayStation Portable (PSP) Console
My belkin N1 router when i plug it in it just flashes the security light and wont connect to the internet
You will need to double-check your security settings. Apparently, the modem is trying to tell you there's a problem regarding this.
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Belkin router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Belkin router.)
Jan 20, 2011 | Belkin N1 Wireless-N Wireless Router
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
My son is trying to connect his PSP game console and it's asking for the security code WEP.
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Hope this is helpful.
* Rating and comments are welcome on this solution
Nov 11, 2010 | Belkin (F5D7231-4) Wireless Router
Says i am connected but when i open firefox it says that i have no network connection... the wireless icon also says it is acquiring ip address
if the message aquiring ip address comes in computer then it says that the wireless router is not giving an ip address to your computer.... check if any static ip address is assigned to your wireless connection...if so change to "obtain ip address automatically".... right click on wireless network name> goto properties > authentication tab> uncheck "enable IEE athentication"
now try to connect again,still not restart the computer once...... this will resolve the issue.... still if it is not connected then check for the security settings in the router... if your computer is XP/MAC, it may not recognize WPA security type.... change it to WEP type and try to connect again....
Apr 19, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
How Can i maintain who can access my wireless connection I have neighbors who can access my wireless connection.I dont want no one other than me the psp and the ps3 connecting to it
you will need to enable security on the wireless network.
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Feb 24, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My xbox 360 will not connect because the WEP keys are off
ahhhh using a router. You need to use a computer that can surf. Google your router model along with default user and password and ip address. should be a 192.168.xx.xx. open a website. Put the ip addy in the address bar and log in to the router. Wireless Security setting will give you the wep and network name
Oct 10, 2009 | NetGear RangeMax Dual-Band Wireless-N...
How do you repair an IP address conflict? I have a wireless network system in my house along with a wireless printer. The IP address on the printer keeps changing and we're either loosing our connection to...
You can assign the xxx number as you wanted if your printer is wireless. For example your Lap top wireless is 10.0.0.3 then set your IP address for your printer is 10.0.0.xxx ( 10.0.0.9) The xxx number can't be the same with any number for any other lap top you have around the house. You can right click on Printer property to go to add Port and put this number in.
Sep 07, 2009 | Averatec 6200H Notebook
Lights wont turn off even if netwrk wires are unplugged..
You'll have to hold your reset button down for atleast 10 seconds, or even more, then you'll have to reconfigure you entire connnection at address 192.168.2.1.
However before doing that, try and power down the whole unit for a minute or so and power it back up, then go to you computer's wireless connection and renew your IP address [that's if you have automatically assigned addresses]. otherwise you might have to check that you router and computer are operating on the same page [ by this I mean, if your router is assigning automatic IP, make sure your computer is not set to use a static IP, In my years of network, this has always been problem I have experienced on some routers]
Jun 21, 2009 | Belkin (F5D72304F5D7000) Router
Connects to Access Point but the internet cannot be found
The main reason why you have this error message because your computer is not getting a valid IP address from teh wireless network, and the reason why its not getting a valid IP address is the wireless security or sometimes called WEP/WPA kay are not type in to the correct place, If you have a WEP enable on your wireless network you will have two option on the Linksys WLAN monitor where you can type in teh security key, you will see two boxes there when you try to connect to the secured network one says Passohrase and one says WEP key1 and if yuo have a wireless key that has a total of 10 or 26 key character you need to type that on the WEP key1 box leave the passphrase blank...But if it still didn't work you can contact this number for help 1-877-787-8749....
Oct 15, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
