Question about Sharp 36U-F810 36" TV
No picture or sound
When the power on button is pressed, you can hear a click sound after a few seconds but no picture or sound. The picture tube seems to energized because upon touching the screen there is static. Is this a start up circuit problem?
  • carlosy Aug 26, 2008
    no picture or sound but the power button is functional. There is static when the tv is turned on.
    Sergeant:
  • 308 Answers
It sounds more like a shut down circuit problem if you can feel static from the face of the picture tube after it tries to start up. There are several things that can trigger a shut down condition on TV's. For instance, if there is no vertical deflection signal present, the set may shutdown to prevent a permanent line being burnt across the front of the tube. If the power supply wasn't regulating the B+ voltage properly, it would shutdown to prevent damage in the horizontal sweep section. Or if the horizontal deflection circuit was defective and allowing the high voltage to climb too high (say above 33,000 volts) then the sensing circuit would trigger a shutdown event. If any of the above sounds like gibberish to you then you will need to take the set to a professional for repair.
Posted on Dec 06, 2006
Your problem sounds like what our RCA does once in a while. The service tech actually suggested we unplug it for a while and plug it back in. I thought he was crazy myself, but it worked with our TV. Henlopen sounds as if he knows a lot more about it though.
Posted on Apr 25, 2007
That sounds just like what my sanyo is doing when i try to turn in on it clicks and tries to come on then it goes out.
Posted on Mar 31, 2007
SOURCE:
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
No picture/no sound.
there is a problem with the heat curcuits leading to the tube
send it into a pro
May 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
Powers off
do you hear any sounds what so ever? Clicks or anything when you press power.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Won't turn on
The clicking you here is the mosfet trying to turn on power on the the oscillator then power to the tranformer. The thing with red wire come from the top to a anode splitter. The question is where the power stops. You know it is going to the mosefets but is the trasformer powering the tubs. Email me for anymore questions Christopherclhurst@hotmail.com
May 25, 2007 | Zenith R40W46 40" Rear Projection...
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Sharp 36U-F810 36" TV Logo
261 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
