Question about SanDisk Sansa Clip MP3 Player
Sansa Clip will not turn on
My daughter's Sansa Clip 2GB will not turn on, which seems to be a common problem. Is replacement really the only option? Is it a realistic option?
I had the same problem but I didn't really do anything about it. After it started doing that I left it on my desk for like a week and then plugged it into my computer and it finally turned on.
Posted on Nov 12, 2008
  • 3 Answers
Instalation free
My Sansa Clip died after installing Rockbox!
Maybe installing Rockbox makes your device corruption. If plug the device to pc, the pc still recognize it, update new firmware from sandisk official site, http://forums.sandisk.com/sansa/
Good luck
Apr 19, 2010 | SanDisk Sansa Clip MP3 Player
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip has seemed to just stop working, it wont come on. what could be the problem?
Respected Sir,
I lost sansa installation cd (2gb). Kindly requesting you to help regarding this matter
Nov 13, 2009 | SanDisk Sansa Clip MP3 Player
When i connect my sansa clip 2GB to my computer it doesnt show in My Computer section so that i can down load music into it
just figured mine out. turn your clip off. put the slider in the hold or lock position. press and hold the center button on your clip. continue to hold while attaching the usb to your clip. keep holding the center button as clip powers up. after appox. 12-15 seconds, your computer should read the clip. i am running windows xp and this is the ONLY way my comp. will read the clip. but it works great!! good luck!
Apr 23, 2009 | SanDisk Sansa Clip MP3 Player
My pc wont let me install new sandisk 2gb mp3 player
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just in case.
Hope this helps!
Apr 02, 2009 | SanDisk Sansa Clip MP3 Player
"No Song" displayed even though music has been loaded, many times
The songs ripped from CD are not in the right format. In Windows Media Player, highlight the Rip tab, click the black arrow under the Rip tab, select Rip Options --> Format --> Mp3. Now, re-rip the songs. Before you transfer these tracks to the player, make sure you delete the tracks that are on the mp3 player now, or else Windows Media Player wil ltell you that the tracks are already there. Now, transfer the newly-ripped Mp3 tracks to your Sansa. Should be good to go.
-Tha Mp3 Doctor
Jan 10, 2009 | SanDisk Sansa Clip MP3 Player
Where can i find the driver for sansa clip mp3 2gb? where i can find the driver for sansa clip mp3 2gb
Go to sandisk.com. Click on downloads. Select sansa clip from the product list, then your operating system. You can get the updated driver and user manual.
Dec 10, 2008 | SanDisk Sansa Clip MP3 Player
Player shuts itself off
There could be a damage or corrupted file in the sansa clip. I suggest to reformat the player. To reformat the player. First turn off the player. Then slide the power switch down it will be showing red, now press and hold the center or the middle button on the player while connecting the player to the computer. It will be detected as a drive on your computer, now right click on it and choose FORMAT, make sure the file system is FAT32 then click start to continue formatting the player. This will erase or remove all the songs on your player but this will fix the problem that you are having
Aug 22, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
