HP PAVILION LAPTOP SHUTS OFF AND REBOOTS AFTER A FEW MINUTES
MY COMPUTER SHUTS DOWN AND REBOOTS AUTOMATICALLY AFTER A FEW MINUTES
    Genius:
  • 1,124 Answers
This issue could be caused by any of the below possibilities
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Posted on Nov 12, 2008
  • 3 Answers
Your laptop could be overheating. Make sure the laptop sits on a solid surface and if it is on a solid surface, you may need to clean out the dust. If you're using it on the couch, bed or a soft surface the laptop is not getting enough ventilation. If its on a solid surface, just get a can of air at any electronic store that sells computers. You will need to clean out the fan on the bottom of the laptop and also the exhaust. You will see the opening for the fan on the bottom and the exhaust will be near the fan on the side of the laptop or the rear. Let me know if this helps.
Powers on and shuts off
I suspect that you have a cooling problem.
Simple and quick to determine if this is the case.
If you have been setting your laptop on a flat surface the fan(s> may be unable to feed enough cool air where needed and your system will automatically shut down to prevent damage. Same results if your fan has failed.
Hopefully it is as simple as repositioning your laptop so that air circulates UNDER it.
I had to mount mine on a wire basket to avoid an overheating problem.
For a quick test: If you have a fan position it, just for a few moments, so that it blows directly on the laptop bottom or aim the center of the fan at the edge of the laptop.
Be sure it has just shut down a few minutes ago. Leave it powered off for about 15 minutes, use fan for about 10 minutes before powering on, leaving fan in place.
If this stopped the on off (I would think OFF then ON if ON then OFF let me know; a very different problem) then be careful to provide adequate airflow when in use!
Jimm
Nov 22, 2012 | HP Pavilion DV9910US Notebook
My HP pavillion dv7 keeps shutting down. I'm trying to run a system recovery back to the factory settings. It got up to 51% done and then the laptop shut off. Subsequent attempts at booting it back up...
Be sure that the laptop is plugged in to the power supply before you start! Are you restoring from an image in the machine or a CD or DVD disk?
Either way this takes quite a while and most manufactures warn you that the machine will reboot a few times (I have seen some take 5 reboots) to complete the task, so be patient.
The last part of your question concerns me. If you power cycled the computer (turned it off then on) half way through the process it could be hard crashed. If you have the CD or DVD dish this would not be a big problem but if you are restoring from an image this could be bad. Let us know.
Ron
Jan 06, 2011 | HP Pavilion DV7-1232nr Notebook
The problem started when I was watching a tv show and my laptop shuts down, then I tried to turn on again, and I couldn't. When I press the power button to turn on the laptop, the keyboard lights come on...
Dear Friend,
HP Pavillions are not good... Buy a new Laptop that dosnt use Nvidia graphics card.
The problem resides in the graphics card Heating up to madness.
If you know how to open your Laptop, Dissassemble it and remove the processor. Heat up the Graphics card with a hair blower for 5 to 10 minutes. put the hair dryer about 1 cm distant to the graphics card.
After that - let it cool and make sure you put back everything correctly, screw it up and Voila...
Your laptop is new again..
Nov 25, 2010 | HP Pavilion Dv6910us Notebook
System shuts down automatically
Turn on Laptop with F8 key or Delete key -
leave the computer on on the bios mode for few Minutes - see whether system turning itself of -
IF NOT - reinstall the OS
IF Yes - check the Hardware -
May 20, 2010 | Toshiba Satellite M35X-S149 Notebook
Pavilion dv4000 PC Notebook: My hp pavilion dv5 laptop runs very hot and then t...
The easiest way to clean it is to use a can of compressed air and blow it through the airflow vents.
Check out this link for other solution.
http://bootmylaptop.com/laptop-shuts-off-after-a-few-minutes/
May 18, 2010 | HP Pavilion dv4000 Notebook
Bought a HP Pavilion 17'' P8600 6GB 500GB nVIDIA GIGABIT LAPTOP. When I start it up after a few minutes it shuts down. this is when power lead is plugged in and also when it is unplugged. Does this model...
When you say it shuts down, does it simply turn off straight away? If so I would say it has a faulty power connection. If it goes through the whole 'Windows is shutting down' processes then it maybe the motherboard which is faulty. Either way it sounds like quite a serious issue.
Nov 21, 2009 | HP Pavilion dv7-1130us laptop
When I start Vista the startup bar shows up and then power goes off to the screen and the computer re-starts again and again. I get the black screen safe mode screen also. Additionally, I.E. shuts down...
Windows is toast, my friend. I hope you have a good backup, and recovery disks. It's probably malware, but the bottom line is Windows needs to be reinstalled.
Nov 20, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My wifes hp dv9000 laptop will boot up and go to the desktop, 30 sec. later it shuts off, then reboots. It started doing this after we used a hp recovery disk. Her computer crashed on her overnight and hp...
You will need to do more trouble shooting. If you can, boot into safe mode and see if system reboots. If it does boot into the bios and see if it reboots there.
If system reboots in all modes then you have a hardware problem and will need to be serviced. However if it does not reboot in the bios then there is a good chance that some part of your windows system is corrupted.
If you find this helpful please rate so.
Thanks
May 06, 2009 | HP Pavilion dv9000t Notebook
HP pavilion laptop shuts down abruptly
It sounds like something is overheating to me. Also, it could be a bad motherboard. Try putting your laptop on a hard surface. I carnt stress this enough. Also, you can try cleaning out the laptops cooling vents with some compressed air (you can get it at pcworld). At the end of the day and it still wont work, send it in for repair. Good luck
Aug 31, 2007 | Computers & Internet
Computers & Internet Logo
2,413 people viewed this question
David Payne
David Payne
