Question about Sony Playstation 3 (PS3) Console
Ps3 loading disc
I replaced the laser in my ps3 60gb model and now when I go to put a disc in I have to put it in almost half way before it will take it in by itself. I have another 60gb and a 40gb, when you put the disc in about a inch or so it will auto accept the disc. Want to know if there is something i did wrong and also on the top of this drive where the opening is there is a small circuit board with some type of sensor or something, the board has a very small black and red wire coming from it that connects to the drives main board, what is this sensor board and what is it used for? Thanks in advance.
  • ellite Nov 13, 2008
    Yes it was one of the wires came out of the small yellow connector. Thought about trying to solder 2 more wires from the optical sensor board to the drive board and see what happens. I know I can buy a used drive as is on ebay for about $60 buck but really don't want to spend that just for the senso, do you know where i could get that part or cheaper drive from. Thanks in advance and also thanks for the reply.
  • 95 Answers
Hey it appears you failed to connect the very small optic sensor. this sensor tells the drive to activate the slot loading mechanism. without it connected the automated slot drive doesnt work..connect it carefully...was it damaged when you removed it?
Posted on Nov 12, 2008
I put a disc in my ps3 the icon comes up but keeps spinning and not loading discs
There might be a problem with your disc drive, you could test it by instead of putting a game in your console, put a dvd or blu-ray in, if the movies load, the laser may be dirty if they don't load, then there is probably a problem with your laser and it would need to be repaired from Sony.
Mar 20, 2011 | Sony Playstation 3 (PS3) Console
Wheni put a disc in the ps3 it does not load up so i cant play on games my software version is 3.21
hi,
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
None of my ps3 games will play but normal dvds all work fine. any ideas?
well, the 40gig model of the ps3 can have either the dual laser lens, or the single laser lens in it. they started out with the KES-400A single laser lens, but somwhere along the line, they started putting the KES-410A dual laser lens in them, which is supposed to be a more reliable laser lens, but they do fail as well. the most common reason why a ps3 won't read ps3 games and bluray discs, but will read dvds or cds is because they have a red diode that only reads dvds and cds, and a blue diode that reads bluray and ps3 game discs. i would say your blue diode has kicked the bucket and needs to be replaced. you will either need to send the system to sony for repair, or to a third part company to have it replaced, or you can replace the laser lens assembly yourself
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
Just recently my ps3 wont play any games or dvd. It loads up everything as normal but whem you put in disc it jusy goes to a blank screen until you remove the disc. yellow ang green light will flash while...
it sounds like your laser is gone you can replace it if you have any knolage of opening a ps3 there are loads of videos of how to do this on youtube i my self had the same problem its not that hard to fix
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Disc never loads
Have the laser replaced as soon as you can .....the ps3 itself is fine you just need to replace the laser only
Oct 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 stopped loading discs
Cleaning the laser on the PS3 rarely, if ever helps.
It needs a new laser because the old one is "burnt out". It's a really common problem with them.
You could replace the laser or the entire Bluray drive.
I buy my parts at http://parts.consolerepairguy.com - the laser are about $75 each and Bluray drives are about $95.
I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
Sep 29, 2009 | Sony Playstation 3 (PS3) Console
System shows that the disc is loading, but does
That sounds like a faulty laser. Unfortunatly,Sony has not fixed this yet and i don't think they will anytime soon. I would suggest cleaning the laser lens first with alcohol and a q tip,if that doesnt work,have the laser lens professionally. If none of the above help,then it's the spindle motor and that can be tested by putting your hand on the ps3 after you slide a disk into the loading slot and feeling for very small vibrations.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 disc drive not working.
You've done everything I would have done honestly. Take a can of air and blow it into the drive to make sure dirt or dust isn't on the laser which could affect if it sees discs or not.
The better thing to try if you are good at opening up your ps3 and then removing your drive and opening that is to take a damp q-tip with a bit of glass cleaner and clean your laser in the drive gently. Then put the drive back together and hook the cables back up to the ps3. You can leave the cover to the ps3 off for this step. Turn on the ps3 and try different blu-ray, dvd's, music cd's, game discs, etc. If it still doesn't read any of them then either the laser or the drive i bad. If it reads some discs and not others then its a weak laser and the laser would need to be replaced.
If you have to replace the laser or the drive, you can do a search on Ebay and usually find them fairly cheap.
Hope this helps and let me know if I can be of further assistance.
Jun 21, 2009 | Sony Playstation 3 (PS3) Console
Discs wont load
Your laser is going out.
It has nothing to do with the system.
You'll have to replace the blu-ray laser in order to have a 100% working machine again.
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
The game console runs but does not read the disc.
Hi my name is Juan and I have the answer you need this playstation 3 has stopped reading games cd's dvds and bluray cd's the problem is with the laser the laser got damage and it needs to be replaced believe me there is no other solution I do fix ps3's is my job so the only solution is to replace the laser but there is 2 different types of laser depending on what model of ps3 you have look on the back of the ps3 there is a white label with the serial # and after that is the model # start with CECH if you can tell me the completed serial # I can tell you which laser is the one you need if you do the job your self the laser cost you like 65-75 dls if you want to replace the completed bluray drive they cost like 145-160dls depending where you buy the lenses and replacing just the laser is more complicated but save some money just need to be little carefully or if you feel you may have a problem doing this I do sell used ps3's as well new and used parts on ebay I am a trusted power seller I can get what you need or I can do the job for you let me know you choice thanks
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
