Question about HP Media Center PC 873n (P9875A#ABA) PC Desktop
Computer keeps rebooting every 30 seconds. Whats Wrong?
My computer acts like it is booting up but then it goes to this black screen and says sorry for your inconvience windows was improperly shut down and gives me a choice to use mode mode configuration or a normal setting but it has a timer on it and then once the timer counts down to 1 then it will act like it's booting up and then comes back to this black screen again. please.
  • 2 more comments
  • Anonymous Jan 18, 2009
    Monitor has no signal, keyboard and mouse not working. tower does turn on at start up. desktop is an hp
  • Anonymous Feb 10, 2009
    hello i am having a similar problem...my computer keeps restarting before it can properly load to windows....I am not able to get into the control panel at all....PLEASE HELP
  • Anonymous Apr 06, 2009
    Computer keeps rebooting every 30 seconds. Whats Wrong?"
    i already try safe mode but still reboot
  • souvikC May 11, 2010
    It could be either an issue with any hardware or any software on your machine. By software I mean windows itself.
    In technical terms this is called a 'No Boot' situation'.
    You do not need to wait for the counter to count down to zero. You can press enter and it will try to boot.
    Please move the highlighted portion (by using the upper and lower arrow keys) to 'Last Known Good Configuration' and press enter to see if it goes into windows.
    Also, if you have the XP CD you may try a repair-install. If you need help on this please reply.
  • 3 Answers
Your computer could be infected. Press F8 a couple of times when you first turn on your computer when you see the HP logo. You will get whats called an advanced startup menu. Choose Last Known Good Configuration. If windows loads successfully, scan your computer with Anti-Virus and Anti-Spyware programs to remove infections. If windows does not load, do the above again but this time choose Disable Automatic Restart. By choosing Disable Automatic Restart the system will give you a blue screen. Write down that information from the blue screen and post it back on here.
Posted on Nov 12, 2008
    Genius:
  • 1,124 Answers
This issue could be caused by any of the below possibilities. Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Answer:
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
  • 153 Answers
It is a Bios safe mode boot up, normally when you boot up and press the key "F8" this safe mode will activate. When this appears again, try select boot windows "normally" by using the errow keys and press enter. If the problem persist then I would advice you to slave your Harddisk in another PC and run check disk in the command prompt.
After slaving your HDD, follow this steps
1.start PC
2.select START
3.RUN
4.type CMD and press OK (something like this should appear: C:\Documents and Setting \trex>_ )
5.(your slave HDD should be E drive) type e: and press and then type CHKDSK and press enter.
6.after check disk done, type CHKDSK /R and press enter
7.type Y
8.Restart the PC
9.and it will auto check and repair any found errors.
Good lack.
This is a virus. Unplug computer to break out of the off on loop. Replug in. Reboot, Hit F2 when promted, if you see a floppy drive that is NOT in your computer, you have 23 seconds to disable it before your computer shuts down are restarts. The virus has your motherboard looking for windows on that non existant floppy instead of your C drive or your CDROM which is why trying to reinstall Windows from your install CD won't work.
Posted on Dec 22, 2009
Compaq desk top starts and shuts down , put new power supply in and I needto get my files from hard drive I have windows xp appreciate all the help I can get
Posted on Apr 26, 2013
  • 25 Answers
Hey....
it might be due to any .bat file on ur system(generally on desktop)...so jst format ur system once(by deleting partition)...
problem will end.
Posted on Jan 29, 2009
    Problem Solver:
  • 12 Answers
This is like 99 percent needs Windows reinstallation. If you still have the CD for your windows then you can just reinstall it in you don't have important files in your hard drive. Otherwise you need to get your files first by putting your hard disk on another computer and save the files to a flash drive or external hard drive.
Posted on Jan 20, 2009
Computer keeps trying to reboot continuously
overheating?
did you do any hardware upgrade befor this problem?
Nov 11, 2012 | Dell Inspiron™ E1505 PC Notebook
ERecovery Management
Mite try taking the disc out when rebooting
Apr 14, 2017 | Gateway ZX4351-47 21.5-Inch All-in-One...
I have an e machine model t3265 it keeps just restarting i pressed the f11 button when i turn it on does nothing but keep restarting trying to get back to factory default help me please thank you also i...
Sorry to hear you're computer is acting up.
Turn the computer off.
When you turn the computer on tap the F8 key(at the top of the keyboard) once every second.
If you get the Advanced options screen choose Last known good configuration by using the arrow keys on your keyboard.
If the computer continues to reboot then do the F8 thing again but this time choose Do not reboot on system error(don't remember exact wording). If you're getting a blue screen, what is the STOP error code shown on the screen?
Mar 14, 2011 | Computers & Internet
My ipod touch goes to a back screen then it goes to a white screen and keeps repeating
Welcome to Fixya
This problem is called the white screen of death. To solve this, you should press the Home button and the Power button together for about 30 - 40 seconds. This process is called hard reboot. You can also try to restore the factory settings by plugging the device to you computer and restore it using itunes.
Thank you!
Nov 04, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
I can't start my computer. Message "start your computer in safe mode"appears on the screen and than screen goes black and after few seconds the previous message appears on the screen.It's like a vicious...
Assuming Win-XP? ... When the computer is booting up (before windoes graphics) keep on tapping the F8 key to boot into safe mode. You should then be able to identify what is stopping Windows from booting properly.
- Have you just installed any software / drivers?
- Check the error logs and device manager to see if anything is wrong
Good Luck
Jan 18, 2010 | Toshiba Satellite P35-S611 Notebook
Won't boot up, windows won't start successfully
In fact, your computer is restarting by itself after a problem. On Windows 98/2000 the blue screen was sitting there until you rebooted the computer. Windows Xp reboot the computer sometimes even without showing any error message. The thing is, if it reboots even if you select Safe mode, something may be wrong in your hardware (i.e. your memory or hard drive). I would bet on a memory failure but it's hard to be sure unless you boot your computer with a memtest CD, you can find it for free the internet and select your CD as booting device when the computer starts. If you cant do that yourself, you can bring it to a local computer store or anyone with good computer repairing skills. If you need more help with this, let me know
Jun 08, 2009 | Toshiba Satellite A105-S171 Notebook
Lol
Its a virus problem dear. Try to load it in safe mode ( press f8 on booting) and u have to scan it for a virus and startup program. Or you have to format it and install a fresh copy of operating system
Apr 05, 2009 | Dell OptiPlex GX280 PC Desktop
My hp pavilion shows default screen
Hi
Have you installed anything before this happen.Try booting it up in safe mode, and restoring it to a later date.
Good Luck
Mar 28, 2009 | HP Pavilion dv6000z Notebook
Acer monitor AL715 blacks out after seconds. Can see screen again for seconds if shut the monitor off and turn it back on. I get a picture when attaching the computer to a projector.
The screen resolution on your PC video card is set to high, the Acer monitor (rather than giving you ANY indication of whats wrong) just goes black. If you have another monitor, hook up to it and lower your resolution. You can also try going into safe mode and resetting your resolution there or deleting your video card and then on reboot into normal mode allowing it to re-install, where you could then reset your resolution.
Feb 20, 2009 | Acer AL1711 17" LCD Monitor
HP Media Center PC 873n (P9875A#ABA) PC Desktop Logo
5,974 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
