Question about Microwave Ovens
Mico only heats 4 to 6 minutes
My GE microwave oven model JES1142SJ will heat for about 4 to 6 minutes and then needs to cool off before it will heat again the top is very hot. I'm handy and can change parts. What part am I looking for.
  • sheryl465 Dec 14, 2008
    i can not seem to figure out how to change the exhaust from font to back.
    Scholar:
  • 68 Answers
Many microwaves require x amount of clearance for exhaust heat, is it installed with the proper clearances?
it is one, not venting and tripping the overtemp,
two, the overtemp module is bad, or the board receiving the signal is bad
Posted on Nov 12, 2008
Model Jvm1330bw002. Why does it do nothing when cooking time is set?
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. If your microwave is counting down but will not turn on, this could be one of your problems to test... ... My Ge Jvm1540dm4bb microwave stopped heating & spinning so I opened it .... Microwave Oven Troubleshooting in MINUTES ~ STEP BY STEP ...
Nov 25, 2015 | GE Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave GE model JES1142 won't start nor even light up when plugged in.
I would remove the outter shell and check the glass fuse inside next to the power converter.
Nov 10, 2010 | GE JES1142SJ Microwave Oven
Cuts off when gets too hot
inside your microwave is a heat censor, if it cuts the microwave off then its to hot for safty have a good look round the back of it to check that the air vents are all clear and that a good air supply can get all around it when its cooking food,,, iv seen so many microwaves tucked away into a small place, and they will all cut out when they get to hot,,,1100 watts gets very hot too!
Jun 06, 2010 | GE JES1142SJ Microwave Oven
My ge microwave doesnt heat up anything
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jddjd
Nov 17, 2009 | GE JES1142SJ Microwave Oven
I ran the microwave with nothing in the oven (obviously by mistake). Now it won't heat the food. Timer, clock, etc works. Is there a simple part that I can replace to solve this problem or have I killed...
You can replace the magnetron tube and , the heating will be restored. this is repairable.
Most magnetron tubes will run in the 120 to 140 dollar range.
Jun 19, 2009 | GE JES1142SJ Microwave Oven
Standard re-heat time value for GE jes1142sj microwave oven is 120 seconds. Is there a way to re-program and lower that time value from the keypad?
No, that is preset in the microprocessor.
You can always enter the amount of time you want instead:
Press Cook Time (or Time Cook) then each digit of the time you want, then Start.
Mar 03, 2009 | GE JES1142SJ Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
