Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
Thin wire broken in front
When you take the front of the machine out, the thin wire that is attached to the back of the front vents is broken. Can I order this part to try to repair it?
    Scholar:
  • 68 Answers
Describe this wire, is it a small silver shiny wire? It is most likely the ni-chrome wire or high tension wire that zaps the particles, I would think thay would have that part available have you called them?
wbwill@sbcglobal.net, if it is obsolete you can mail it to me and I will take a look
Posted on Nov 12, 2008
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
HOW TO REMOVE FRONT CONTROL PANEL IN ECOQUEST AIR PURIFIER
behind the front panel fingerboard on each side there is a screw hidden. You have to very slightly and gently with a fine bladed knife pry up those left and right sides to expose the screw. Its a thin piece of plastic covering the screen. Be very careful because there are electronics imbedded in the fingerpad that you are prying up. Gently lift the sticky covering only enough to get to the screws. It can be done but be careful.
Apr 13, 2010 | Ecoquest Fresh Air Air Purifier
MACHINE TURNS ON FOR 30 SECONDS AND LOUD CRAKLING SOUND HAPPENS THEN MACHINE TURNS OFF...
Sounds like the power is arcing, Probably broken porcelain insulators. I wouldn't recommend trying to use it, there is some really high voltage in there. Replace it or send it out for repair.
Sep 07, 2009 | Brookstone Air Purifiers
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Ionic Pro makes weird buzzing noise
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Jan 03, 2009 | Ionic Pro TURBO Air Purifier
Ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
Nov 03, 2008 | Sharper Image Professional Plus Ionic...
Problem
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Aug 05, 2007 | Sharper Image Ionic Breeze SI719 Air...
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
The low button light is going out.
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
255 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
