Question about GE JE1640WA/GA Microwave Oven
Microwave works with the door open
It started in the last few weeks. We use our microwave and when we open the microwave starts to run (lights are one, turn table turns). Again, it appears to be running. I don't know what it is causing the problem. I tried to close the door harder and sometimes it stops doing this, but it comes back after a few tries. Do you have any suggestions? Thanks, Carlos
  • 2 more comments
  • Carlos Amaral Nov 11, 2006
    Your comment is right on the money! I have committed several of the things you mentioned (open the door before it finished, closing the door too hard - my kids do that all of the time). It sounds like it is time to purchase a new one. The door frame is also broken.
    Thank you again!
    Carlos
  • needmyjoe May 28, 2008
    Lately when the microwave is done, I open the door, remove the item, close the door and voila! It starts running on it's own! The light is on, the fan is on, the table is turning, but there is no time showing...do you think this is also from shutting the door to hard too many times?? Time to get a new one maybe??
  • Anonymous Mar 16, 2014
    table starts turning when I close door, before I set the time,and microwave isn't getting hot
  • Anonymous Mar 23, 2014
    THE MICROWAVE TURN OFF, THEN TURNS ON BY ITSELF. SOMETIMES WHEN CLOSING DOOR.
  • GE Master
  • 9,156 Answers
The top door switch is almost certainly defective or loose. Most likely the latter, and possibly due to a loose or broken mount. Chances are that only the fan and light are on, but it's not wise to take chances with microwave energy, whuch can cause burns and fire. One way to possibly test this theory is to pull up gently on the door and see if it stops doing it. But that's not a foolproof test. A broken or loose mount can be caused by inadequate plastic or improper assembly techniques during manufacturing, by slamming the door, or other physical damage. Bad door switches are usually caused by opening the door while it's cooking instead of hitting the STOP KEY first. I have a helpful text file on door switches with safety tips that will help you. You can find it by searching on Yahoo.com (not Google) for microwave safety.txt Good luck and be safe!
Posted on Nov 11, 2006
  • marci958 Dec 01, 2010
    This comment is right on. So if it is a bad switch then what?
Opening the door tripped breaker a few times, now microwave will not power on.
Sounds like a bad switch should have three primary, secondary, and monitor switch after 5 years change all 3 they are not the same primary and secondary are NO ( normally open ) and the monitor NC ( normally closed ) unit will not come on the fuse on the filter board is blow this usually shorts out the filter board change the switches first and replace fuse may not have to replace filter board hopes this helps.
Apr 06, 2015 | GE Monogram ZE2160SF Convection /...
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
When door is shut light comes on but does not start microwaving. I can make it start by holding the door up from the bottom. How to fix?
We had a guest for a repair at our Repair Cafe last week, and he did have a Sharp Microwave, that had the same problem. Maybe looking into the manual will help, see url Sharp 319F Operation Manual
Feb 13, 2014 | Sharp R-319FW Microwave Oven
Fan runs when microwave door opened
-You're already answer yourself.
Good luck
Mai
Jan 22, 2018 | GE JVM1650 1000 Watts Microwave Oven
My JE 1860 microwave starts working when I open the door.
It sounds like the door switch is bad. It may be that the switch is shorted inside. I would think it may really run with the door open, and microwave you.
Mar 06, 2010 | GE JE1860 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Sharp Carousel Micowave
One or more door switches is bad, or the switch mount is loose or broken. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 23, 2007 | Sharp R-320H Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
816 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
