Other Thread I added some extra information in that thread about my computer issue if you'd like to view it. I don't mean to be pushy, I'm just trying to get this issue solved as soon as possible. I have a feeling, or a fear rather, that my motherboard may be to blame. Someone else on a different forum described the same issue I'm currently having, and said they had to end up replacing the motherboard because it was to blame. From what I've described, does it sound like this is the problem? What's odd is that the previous PSU before this one still keeps the system running, just with crashes every now and then, but still running, and I have no idea why that could be.
    Scholar:
  • 42 Answers
This thread should now be closed, answered here: http://www.fixya.com/support/t1237433-system_fails_boot_up_after_new_power
Posted on Nov 12, 2008
I got a bernette 134d overlocker and the Nr 3 thread keep on breaking. What's wrong?
Most often, it is misthreading. Remove all the threads from the machine. Then rethread each thread in the order specified and verify the thread path is correct for each. Also, when threading the tension mechanism, give each thread an extra little tug to make sure the thread is seated completely.
Oh yes, very IMPORTANT. Always raise the presser foot when threading the machine!!!
FWIW, when a thread breaks, trying to rethread that one thread will not resolve the issue because it is being threaded out of order. If rethreading the one thread doesn't work the first time, just bite the bullet and rethread every thread.
The other possibilities are the tension is too tight, poor quality thread, or a burr somewhere in the threading process of that thread is snagging the thread.
Jul 03, 2017 | Sewing Machines
Future quartet beeps when sewing,only allows 5 stitches then beeps what does this mean???
It could be a low bobbin sensor issue (either bobbin is too low, or sensor is out of alignment/has lint blocking it). Or it could be a check spring/upper thread sensor issue. You can check to see that when you are threading the upper thread; check that the thread is catching in the check spring(this will be a very small spring in the thread path--usually step 3--). You may have to remove the head cover to see. Try cleaning the bobbin area and rethreading the upper thread.
Jan 04, 2017 | Sewing Machines
I need to know why i have extra embroidery string get yammed in my bobbin area?
Yammed is not a word .contact the MFG's website , perhaps tech support can help you
Nov 24, 2016 | Sewing Machines
I need to know how to thread a empisal purdy 444 sewing machine
Most machines thread basically the same.
Thread spool
Thread guide
Thread guide
Tension
Take up lever
Thread guide
Thread guide
Needle.
There may be an extra or one less of the guides but for the most part I've been able to thread any machine.
Good luck and god bless
Angela
Sep 11, 2016 | Sewing Machines
I have a white speed lock 234 serger and cannot get it to chain off. The thread bunches together
Yes, thread the upper looper first, the lower looper next.
***Make sure that you have the presser foot RAISED during the ENTIRE threading process until you get to the point of threading the needles.
The second to last step in the lower looper process is to make sure lower looper thread DRAPES over the top of the upper looper & thread, then both thread tails get pulled under the presser foot and toward the back of the machine.
Give each thread a little extra tug as it goes through the tension disk to make sure it is seated. Verify that all the threading steps have been followed. Any skipped steps, extra thread wraps, or incorrect threading will most likely cause a problem.
Make sure you have brand new needles before threading. If one is bent or damaged, you will probably have issues with skipped stitches.
Set all the tensions to the midway point (the factory standard for regular chain stitch). The tensions can then be tweaked when the machine is correctly creating a chain.
If the machine messes up, breaks a thread, comes unthreaded, etc., save yourself some time and frustration and RETHREAD everything from the beginning. Trying to rethread out of order usually fails!!!
Once you are more comfortable with your machine, you can try fishing a thread, but even experienced serger users still have trouble with this.
Aug 03, 2016 | Sewing Machines
Unable to remove bobbin from bobbin threader till almost all thread removed. Viking 1+
You could stop the bobbin filling process just before the bobbin is "full."
Most machines have a finger that rides against the area being filled; maybe this is bent?
Feb 22, 2015 | Husqvarna Sewing Machines
Melodie 40
I\'m not sure what you mean by "reel", but if you are referring to the spool pin which holds your thread, then you don\'t really have to have that. I use a spool stand instead. Then I can use any kind of thread without having to buy the little bitty spools. This is just an example of one style of thread holder. It is by far the cheapest way to replace a missing thread pin.
Amazon com Single Cone Thread Stand With Metal Base Thread Cone Rack
Some people also use a simple cup, and drop the thread inside, so that it doesn\'t unroll all over the work surface. Then thread the machine normally. If the thread needs to be directed to the first spot, a binder clip, attached to the handle of your machine, works really well as an extra "eye" to put the thread through, and secures it quite well.
Mar 10, 2014 | Singer 2662
Can't get the needle thread to loop over the bobbin thread. The bobbin thread is already thru the hole.
You only need the thread to loop over the bobbin thread to bring up the thread when you are threading the machine. If, you mean it is not sewing after threading then I need more information.
Nov 17, 2010 | Singer Pixie Plus Sewing Machine
Computers & Internet Logo
280 people viewed this question
David Payne
David Payne
