Question about HP Color LaserJet 2600n Printer
There is no numeric code. It only says Sensor error, turn off then on. When I do switch it on the problem is still there.
  • HP Master
  • 4,338 Answers
There are several sensors in this unit, paper feed sensor, fuser sensor etc. One of them may be clogged up with paper dust.
see if this helps:
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
Joe
Joe
Posted on Nov 20, 2008
With me problem on konica minolta 7235 show error code f35-8
1. Turn OFF the SW2 (sub power).
2. While pressing the copy quantity setting button 2
and 5, turn ON the SW2 (sub power).
3. [Software DIP SW setting screen]
Select a DIP switch number.
Use the or key or numeric
keys.
To use numeric keys, press the DIP
switch number key at the left before
entering a DIP switch number.
select Dip 3 1 to 0 from 3 1 1
Mar 22, 2016 | Konica Minolta Office Equipment & Supplies
How can i remove error code c 448 in toshiba e studio 5540c
Step 1: Remove all the paper that is jammed in the machine. Follow the steps on the touch screen to locate the jammed paper.
Step 2: Turn off the copier with the power rocker switch on the right side.
Step 3: Hold down the 8 and 0 on the numeric keypad while turning the machine back on.
Step 4: Enter 400 on the numeric keypad and then press the Start (copy) button. As you type the 400 will show up in place of the D
Step 5: Enter 0 on the numeric keypad and then press the "Enter" button on the touch screen.
Step 6: Power down the machine with the same power rocker switch as in Step 2.
Step 7: Turn on the machine with the power rocker switch.
Dec 31, 2015 | Toshiba Office Equipment & Supplies
I have a kodak esp office 6150 printer that when its powered on says document feed paper jam but there is nothing there. i press ok and it says rear access cover not attached (code 3514) but the cover is...
Error codes can't be bypassed. You have to solve the problem. Sometimes the sensor itself is the problem. Or the logic board it is communicating with. But you really have to investigate the whole paper flow, if not just a scrap of paper is in some corner. Then switch off the printer complete (remove the power cord is you can't find the power switch) and switch on again. If the error comes back, you have to call the service centre, sorry.
Jan 09, 2015 | Kodak ESP Office 6150 All-in-One Printer
What does code c6230 mean?
C6230
Fuser thermistor 1 edge break error
Resetting the fuser problem data
Enter 10871087 using
the numeric keys.
Enter the maintenance item U163
number using numeric keys.
Press the start key.
Press [Execute].
The fuser problem data is initialized
Turn the main power switch off and on.
Apr 30, 2014 | Copystar CS-3500i Copier, Printer"
Harley engine codes
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive.
P0222 TPS2 Low
P0223 TPS2 High/Open
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0373 CKP Sensor Intermittent
P0374 CKP Sensor Synch Error
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P1001 System Relay Coil Open/Low
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P1270 TGS Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1353 Front Cylinder No Combustion
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1356 Rear Cylinder No Combustion
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High P1510 EFI Limited
Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P1514 Air Flow Fault
P1600 EFI Module Processor Internal Error
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation
Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body Range Performance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2135 TPS Correlation Error
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
U Codes
U1016 Loss of ECM ****** Data
U1064 Loss of TSM/FSFM ****** Data to ECM
U1097 Loss of Speedometer ****** Data to ECM
U1255 ****** Data Error
U1300 ****** Data Low
U1301 ****** Data High
Harley Davidson 2008 DTC Code Reading (draft)
Harley Davidson DTC Codes - Unofficial Guide Page 3
B Codes
B0563 Battery Voltage High.
B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
B1123(HFSM) Left Turn Output Short to Ground
B1124(HFSM) Right Turn Output Short to Ground
B1125(HFSM) Left Turn Output Short to Battery
B1126(HFSM) Right Turn Output Short to Battery
B1131(HFSM) Alarm Output Low
B1132(HFSM) Alarm Output High
B1134 Starter Output High
B1135 Accelerometer Failed
B1136(HFSM) Accelerometer Tip Test Error
B1141(TSM) Ignition Switch Low/Open
B1141(HFSM) Ignition Switch Low/Open
B1142 Smart Security System Internal Fault
B1143(HFSM) Security Antenna Short to Ground
B1144(HFSM) Security Antenna Short to Battery
B1145(HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
Apr 11, 2014 | 2007 Harley Davidson FLHRC Road King...
I ahve an error code 2 coming up with my Whirlpoos ADP 6000Wh dishwasher?
A couple of sites I know seem to agree. They say:
F2 error fault code
This is a water leak, which has operated the float device by dumping water into the base of the appliance. The anti flood float device switches off the incoming water valve and operates the drain pump until the Water Indicater (pressure switch or Turbidity sensor) indicates the sump empty.
  • Water is in the bottom tray
  • Floater or float switch switches off the water valve and the electronic switches on the drain pump until pressure sensor reports that it is empty. There are numerous causes for this fault, but it all usually comes down to the fact that something, somewhere is leaking. To cure this you need to find the leak.
    Jun 23, 2011 | Dishwashers
    Code error e54 copier.i need the reset codes
    - Possible Causes -
    · Thermistor short
    · Defective ac drive board
    · Defective main board
    · Fusing harness shorted
    To reset code :
    1. Turn on the main switch.
    2. Enter "71" by using the numeral keys.
    3. Press and hold the Clear/Stop key until a dot (·) appears in the top left
    corner of the Copy Counter and then release it.
    4. Press the Clear/Stop key again and then press the Lighter key.
    NOTE: "5" will blink in the Copy Counter to show that the SP mode has
    been accessed.
    5. Enter the desired SP mode number using the numeral keys.
    When the E52, E53, or E55 conditions occur, for safety reason
    they cannot be cleared by turning off and on the main switch. The
    following procedure must be performed to clear these service call
    conditions:
    2. Turn DPS 101-1 on and off.
    3. Turn the main switch off and on.
    Jun 16, 2011 | Ricoh FT3713 Copier
    My copier uses ricoh 320 toner, it is black en white and its displaying error code e 54. what are the reset codes.
    - Possible Causes -
    · Thermistor short
    To reset code :
    been accessed.
    When the E52, E53,E54 or E55 conditions occur, for safety reason
    conditions:
    F3 f4 f8 on a ge modeljtp15wdw2ww
    GE Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F2
    During
    BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
    If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
    Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2
    During
    CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
    If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
    Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F3
    or
    F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC). F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits Check wiring and test operation of switches. FD Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. Replace probe if all else checks out ok. FF Loss of door motor safety switch Replace the oven control (also called clock or ERC). FFF Control error, failed EEPROM Replace the oven control board (also called clock or ERC).
    The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
    An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).Here is a list of error codes and corrective action that should be taken. Mike
    Nov 23, 2009 | GE JTP15 Electric Single Oven
    Hitachi Aircon
    According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
    Jan 09, 2008 | Heating & Cooling
    HP Color LaserJet 2600n Printer Logo
    258 people viewed this question
    Ben Johnson
