Question about Kenwood VR-407 Receiver
Can I use a microphone with this receiver?
If so, where do I plug it in? Also, any suggestions for the type of microphone I should use would be helpful. I usually use this receiver at home for surround sound. In a few weeks I'd like to use it at an upcoming party I am having. I just want to be able to make an announcement through my speakers to a group of 50 people. Sorry for the ignorance, but I am not at all technical when it comes to audio. Thanks!
  • 24 Answers
There would have to be a jack in the back labeled "Microphone" for this to be possible. I found a picture on the web showing the rear and am not seeing this at first glance. Do you have your owner's manual? The only way to do what you want is to amplify the mic with a mic driver and then plug it into one of the line inputs. A trip to Radio Shack could help here. Hope this helps.
Posted on Nov 11, 2006
SOURCE:
I have TX-SR503 onkyo receiver. I want to connect a microphone to it so that I can do a karaoke. The unit does not have a socket for microphone. It has a socket for phones. This socket does not appear...
The reason that jack doesn't work for a microphone is because it's a headphone jack. It's meant to send a signal out to headphones, and it doesn't work as an input. If the receiver doesn't have a microphone input jack (and it would be clearly labeled as such), you'll need to connect your mike through the auxiliary input. You may be able to connect with nothing more than an adapter to switch from the plug on the end of the mike cable to the RCA jacks on your receiver. The output level on some mikes may be high enough to drive the auxiliary input as-is. More likely, though, the mike will need a little boost to make it work with the receiver. The receiver needs a "line-level" input, which is higher than the output of most good-quality mikes. To get the mike up to line level you'll need a microphone preamp. There are many types from many sources, at a wide range of prices. Here's one I have used as an example.
You might also want to look for a small mixer like this. The mixer would let you combine your mike and music source into a single line-level output you could run to the receiver, and use the receiver just for the amplifier function.
Feb 06, 2011 | Onkyo HTRC180
Upon powering up my Onkyo TX-SR605 receiver, it enters Audyssey setup mode even though the microphone is not plugged in. Even if I plug in microphone and remove it, it still stays in Audyssey mode and I...
I have the same problem and it is not speaker wires, cables, or dumb remote codes (really, remote codes.) I'm taking mine in for repair, and not reliying on straw grasping, speculative solutions.
Jan 25, 2011 | Onkyo TX-SR605 Receiver
My Onkyo RC-160 will not come out of the audyssey calibration mode. The microphone is not plugged in, I have tried a hard reset, pulling the power plug and nothing will bring it out of that mode.
It could be bad connection in microphone input jack and receiver think that the microphone is still plugged in. try to plug/unplug the microphone several times it should clear internal contacts of the connector and resolve the issue.
Jan 21, 2011 | Onkyo HT-RC160
I have a shure UT4 reciever,what microphone that will work for that type of reciever? my was lost,thanks
Only a UT transmitter will work with that receiver. The transmitter must be on the exact same frequency as the receiver. Shure discontinued the UT series several years ago, so it will not be easy to find one.
Dec 30, 2010 | Shure UT12485TD Professional Microphone
My shure receiver is stuck on channel 3 and it doesn't let me pair it with my transmiter, why is it doing that?
I suggest calling Shure. They can assist you with troubleshooting. Call 847-600-8440. Make certain you have the wireless system with you so that they can walk you through some possible solutions.
Sep 20, 2010 | Shure PGX-4 UHF Diversity Wireless...
I am trying to use a microphone with the Insignia Receiver 5.1 Channel. I am plugging my microphone jack into the microphone set-up slot. I turn on the button but get no sound through speakers. What do I...
Check if the impedance of the microphone is the same of the microphone set-up slot. High impedances devices such as microphones have to match exactly between jack and input. Good Luck.
Flavio?BRAZIL
Jul 19, 2010 | Insignia Audio Players & Recorders
No sound playing through microphone
The microphone included with this receiver is for audio adjustments only. That's the "Audyssey Laboratories' MultEQ® six-point auto setup and room calibration system". You cannot hear yourself speaking through the microphone.
Nov 26, 2008 | Denon AVR-1905 Receiver
Set-up wireless karaoke Mic.
I can't seem to find any technical details on the output specifications of the karaoke mic, but IF it outputs in consumer standard RCA format (a cable with two ends, one red and one white - often seen with a third yellow cable for video), then you should be able to plug it into the back of the receiver without trouble. Simply choose one of the audio connectors in the back to function as your microphone playback system - I suggest the DBS connector, unless you have a satellite system already plugged in.
Connect the Red RCA cable to the RIGHT channel port on your receiver and the White RCA cable to the LEFT channel (Red = Right). Now, select the DBS (or whatever port you plugged it into) using your receiver remote control. Hit the "ANALOG/DIGITAL" button on the remote until "ANALOG" mode is displayed.
If you want to connect the mics to a Karaoke system using the same receiver, simply unplug the White RCA cable from the Microphones, and plug in the White RCA cable from your karaoke device. Now, you'll get music playing from one side of the speakers, and mic playback from the other side, simulating the karaoke experience.
NOTE: If the microphones do not have a RCA plug on the back, please post a picture of the reverse of the Microphone receiver, and I will see what I can do to help you further.
Dec 28, 2007 | Trident JT-306A Microphone
Shure buzz
check the lead connecting the receiver to system by replacing it out. Check that the correct power supply is still being used.
Dec 12, 2007 | Shure Beta 58 Microphone
Kenwood VR-407 Receiver Logo
153 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
