My monitor keepp going to a black screen but it still has the power botton on
  • souvikC May 11, 2010
    1.What happens to the power light after the monitor goes blank? Does it blink or change color?
    2.How does the pic come back (if it does)?
    3.What are the status lights on the computer when this happens?
    4. Have you tried the same monitor on the diff computer, or a diff monitor on this computer to see if the issue reoccurs?
    5. Which make and model of monitor do you have, and how old is it?
Try to log in safe mode and if you didn't encounter the problem while on the safe mode, i assume there's a conflict with MS software distribution pack and video card driver. go to system restore if you can un restore point says software distribution pack then restore your pc before in an early stage before you have the distribution pack.
Posted on Nov 12, 2008
Screen wont turn on at all hit the power botton screen stays black
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 13, 2010 | Hannspree HW191D LCD Monitor
You may have failure in the power supply, or inverter back light circuits, you need to open it up and inspect the inside for such thing as bad caps, fuse, etc,. See example of failed monitors due to failed components: http://s807.photobucket.com/home/budm/allalbums
Mar 22, 2010 | Hannspree HW191D LCD Monitor
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Feb 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
HP F1903 monitor
sure the F1903
is a LCD monitor but is old , it has
and CCFL black lamp.
it has board inside that is the power supply /inverter
this board runs the lamps.
the lamps love to fail after 10 long year of service
so when monitor fails, push the menu botton on the front
is the OSD menu dead (monitor brains inside)???
see bottom of this page , see CCFL and PCB there?
if lamps bad replace them
if PCB bad replace it, seen sold on Ebay , vastly, there.
http://pcdied.com/black-screen.html#CCFL-examples
some of these old monitors.
have silly internal sleep mode,
turn that off. (push menu button on front)
see OSD (on screen,display menus)
see settings
see power saver mode, turn it OFF,
Jul 28, 2017 | HP Pavilion F1903 19" Flat Panel LCD...
Hp on start up windows starts up but screen is black
we may need more details:
it may not hurt to check the obvios first: is your monitor data cable connected properly to your tower?... is your power cable connected? is the monitor on??
if screen is on but it's just black the simple possible causes are:
1. your brigtness settings are all the way down... adjust with bottons on your monitor
2. your monitor may be going bad... try to test the monitor on a known good pc
3. your video adapter/controller may be bad... borrow another monitor and test to see if you get a picture.
if after doing 1,2 and 3.. .3 is what you see as the cause, you may have to replace your video adapter.. a. if it's the one that came with computer... get/replace the video card.
if replacing video card is not working for you... try to check memory
Sep 21, 2008 | Computers & Internet
Hp monitor black screen
Check for the updated drivers as well as your video card, if you have an internal video card and have tested it (your computer) on another monitor it is more than likely the inverter in the monitor the coils (on the mainboard) need to be resoldered more than likely.
Check the backlight as well
Jun 24, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
How do you unlock the power button?
press the down and the power botton both at the same time end hold it for 20 second then release that´s all
May 20, 2008 | AOC 19LVWK LCD Monitor
Black screen; blinking power light
are using dvi cable did u try to hit the input botton on screen itself thx nick
Feb 07, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Problem with Dell E152FP Monitor
If you open the monitor up, on the inverter board is a 1000uF 16v capacitor that goes bad. If you replace that it should fix the problem. Look at the top of all the capacitors and you should see one that's popped up on the top, that would be the bad one. Some soldering is required. Make sure you put the negative white stripe on the white side of the silk screen on the board! Its a simple fix just sounds difficult.
Dec 10, 2007 | Dell E152FP 15" Flat Panel LCD Monitor
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
