Question about Garmin StreetPilot 2620 GPS Receiver
Garmin streetpilot 2620 in demo mode
My son tried to upgrade my gps and in the mapsource unlocking code typed DEMO.  well now my streetpilot 2620 is now in demo mode.  HOW DO I GET OUT OF THIS/ FIX THIS.
How do you do a Master Reset?  i found out by holding menu & find i get a dianostic menu and the cornice hard drive is shown as unknown.  i try to transfer from device via Mapsource but get error : Req memory for installing maps is missing from GPS.
Someone please help before i ring my kids neck!!!
  • Anonymous Mar 17, 2009
    fmy garmin dosen't start
  • 3 Answers
If it says cornice drive no found when in diagnostic mode then the Hard drive is probably toasted - a common problem. I salvaged a hard drive out of a unit with a broken screen but the new Frankenstein unit required a new unlock code. The 2610 model came with maps that can be used on a 2nd unit so I asked Garmin to give me an unlock code for my rebuilt 2620 that came from a 2610 that had been stolen form my car. Otherwise the unlock code will cost you $99.
Posted on Mar 11, 2010
Do you have any unlock code for your unit? Delete this code "demo" from MapSource and put unlock code for your unit and try to download to unit a small part of maps.
Posted on Jan 27, 2009
SOURCE:
Is there any updated map for streetpilot 2620 since 2008?
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390193775928
Here is the search for EBAY:
http://shop.ebay.com/i.html?_nkw=city+navigator+2009
Here is the item on Garmin's site:
https://buy.garmin.com/shop/shop.do?pID=8465
Listed as:
City Navigator® North America This product has been discontinued but is still available for purchase.
It is $99.99.
Good luck, and let me know if you have any other questions.
May 11, 2010 | Garmin StreetPilot 2620 GPS Receiver
Where can I get a new 2.2 GB magicstor hard drive
There are many different compatible CF cards for the removable CF version of the 2620 that will work. A search of "Garmin 2620 CF" will yield what you are looking for for around $15.
Mar 08, 2010 | Garmin StreetPilot 2620 GPS Receiver
My Garmin StreetPilot 2730 won't hold its settings.
Do a hard reset.
Turn the unit off, then hold down the menu and map buttons, simultaneously, then turn the unit back on and continue to hold down the buttons down for at least five more seconds, then the unit will power up. At that point it's like the unit is being used for the first time and you will have to reset everything. You will lose your XM presets, but the MP3's were still there.
Also after if this does not work, plug in your garmin and mount it, mac or pc whatever, then go in your garmin file erase all maps should be gmapsupp.img or gmapprom.img. Reload your maps from mapinstall.
Jan 14, 2009 | Garmin StreetPilot 2730 GPS Receiver
Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Jun 11, 2008 | Garmin Rino 530 GPS Receiver
Pc software
Go to the following link to get mapinstall.
http://www8.garmin.com/support/download_details.jsp?id=3291
You will need to purchase Mapsource NT 2008 to get the latest maps. The upgrade will come with a serial number which you will use to register on garmin's website. You will also need your unit ID, it can be found on the back of your unit, when you register with Garmin. Afterward you will get your unlock code (25 characters). You will enter the unlock code in Mapsource before installing the maps onto your Garmin.
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin Streetpilot 2720
I fixed my C530 on my own. Garmin support will not give you this solution.
I attached the GPS to the computer with the usb cable. I used the file explorer in windows to view the file system on the GPS. I sorted the files by date. Then I moved the files that had a newer date than the last time the GPS worked, to an backup folder on my computer in case I need to restore the files to the GPS again. I than disconnected the GPS from the computer and restarted the GPS. The GPS works perfect now and doesn't enter the demo mode any longer.
Oct 08, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
436 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
