Question about ASUS P4B266 Motherboard
Computer doesnt start
I just changed CPU fan on my computer from a standard intel fan to a zalman fan, after 1 hour of bending and fighting to get the fan in... the cpu fan starts spinning, the harddrives seems like they are booting up... But no signal to the usb and the videocard doesnt seem to work anymore >.< the usb-problem might only be that windows didnt boot up yet, so the external devices doesnt get any contact... but why no signal to the monitor??? ->
    President:
  • 2,961 Answers
Yes can only echo other solution, you should have easily been able to replace fan, so you have probably damaged the mobo, or unseated your graphics card. But more than likely the circuitry to the agp slot and usb connections are damaged
Posted on Nov 12, 2006
    Problem Solver:
  • 28 Answers
It sounds like your struggles may have damaged the motherboard. See other issues in this forum with this motherboard - partcularly with bowing of the board. Too much bowing can cause internal traces in the PCB to break. Only way to tell now is have it professionally looked at.
New system biuild won't boot to bios. Gigabyte GA-Ep45-UD3L Rev 1.0, Zalman CNPS9500, Intel Q8400, G.Skill 1066 2X2GB Memory, Radeon HD 4650 Graphics card,Antec Sonata III case w/ Earthwatts 500W PS. When...
ok well make sure you have the right ram look in the manual and see if it needs to be non error correcting or error correcting (non ecc or ecc) and if it needs to be registerd or unregisterd ram (AKA: bufferd and unbufferd Ram) dont run it very long with no CPU FAN or it will burn and check that fan by pluging it in someware els thats strange cpu fan is always running when mobo is on.
Feb 24, 2010 | Intel Motherboard
Zalman VF2000 LED fan starts then stops right after boot
Sounds like a defective fan, something having to do with the thermal probe, it causes the fan to speed up when cpu gets hot and to slow down when the cpu is cool. I suggest returning it for another one
Feb 10, 2010 | Computers & Internet
Changed motherboard
when you boot your computer open up the bios menu, i forget which tab it is under but there should be an option called S.M.A.R.T fan or SCSI if it is disabled enable it this should fix it, if you do not have this option or if it doesnt work this is a link to a fan control program called speedfan http://www.almico.com/sfdownload.php
May 28, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Cpu fan not running fast enough
This will depend on the motherboard you are using.
however, you need to make sure that the CPU fan lead is plugged into the correct plug on the motherboard... for example, I have an Intel 975xbx motherboard and it has 4 fan plugs, but only one of those is for the CPU. The others are for front/rear/top fans. If the CPU fan is plugged into one of the secondary ports, the CPU fan wont speed up correctly.
Also, some BIOS settings in the motherboard allow you to enable or disable automatic fan speed adjustment, and also set the temperature points.
Dec 03, 2008 | Zalman Tech Computers & Internet
Cpu cooling
The ZALMAN CNPS9700 is the best air cooler on the market.It looks cool and is quite easy to install. I have one in my box and I have 34 degrees with an Intel Quad core running 1 Gigahertz over stock.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
Nov 01, 2008 | Computers & Internet
ASUS cpu fan required
CPU fan is supplied with the processor it self you need to contact your processor company
it you are talking abt the Casing fan then just get an ordinary casing from from a hardware shop
Dec 13, 2007 | Zalman Tech Zalman North Bridge Chipset...
Fan noise
It depends on your CPU. As far as I know, some Pentium 4 has it - Enhanced Intel speedstep Technology. If your CPU supports it, you need to enable it in the BIOS. Good luck.
Oct 19, 2005 | ASUS Pundit-R Barebone
ASUS P4B266 Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
