Question about Philips 32PT5441/37 32" TV
TV Problem My television has lines running across the screen. It started at just the top but now every time we turn on the tv there are a few more and now they are almost half way down the screen. We still have color and sound. The tv is only a year old. Is it going to need to be replaced?
  • Jennifer Hood Nov 11, 2006
    The lines are white and the picture isn't distorted to badly. I am currently living out of the country and finding a tech is a little hard is it something I can do?
  • 24 Answers
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Posted on Nov 11, 2006
  • Rick Young
    Rick Young Nov 13, 2006
    It depends on your comfort level when working on TV chassis. You mentioned that you're out of the country. Is the TV standard where you're at the same as the one where you bought the set? That could explain a lot.
    rix20601
SOURCE:
TV TURNS ON,LINES ACROSS SCREEN THEN TURNS OFF BY ITSELF
sounds like a vertical problem, usually you'll see one white line across the screen, but one I worked on would come on and the bottom half of the picture was gone and there were lines across the top of the screen.
If you know how to solder & can find the vertical output chip then you could try resoldering the pins. If this doesn't fix it then it needs new parts.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment. The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
Jan 03, 2009 | Televison & Video
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
I have a Sony Big Screen Projection TV
unless you work on t.v.s this is nothing you can service.check your warranty &/or call a qualified service tech.hope this helps
Nov 15, 2008 | Sony KP-57WS500 57" Rear Projection...
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Mitsubishi TV CS35313
bad caps in the vertical output and jungle IC section. Check all boards for black runs, leads near/on caps, they leak and eat the copper runs.
Nov 03, 2007 | Televison & Video
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Nov 02, 2007 | iLO 2600 Television
Toshiba 50h13 projection tv
You have a bad hyper board part #23148024.  The part is NLA.  I have one in stock or you can have yours rebuilt at PTS Electronics 800-844-7871.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 02, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 32PT5441/37 32" TV Logo
163 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
