Question about Canon FAX-B820 Plain Paper Bubblejet
Can not print the incoming fax as well as cannot copy a page
While giving a page for coping it is scaning the page but cannot print the page . A white sheet is coming out.
  • 318 Answers
The scanner unit don't reach the scan possition.If you open the front cover,check and see if the is no obstruction in the scanner parth to flip down to the scan possition.Pull the scanner unit a few times foward down and backwards up.If that dont work the grease on the scanner clutch might cause the scanner not to go to scan possition.For service of that clutch you will have to take it to the Canon dealer.
Posted on Nov 12, 2008
What will be the reason for canon sensys fax-L 150 coping dark page but faxing and printing is ok.
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Sep 30, 2016 | Canon i-SENSYS FAX-L150 Laser...
Hp m1536 scanning black
Replace CCD scanner head unit with flat cable...I think UR from india, you can get it in indian market..
Example image of scan head:
Aug 10, 2015 | HP LaserJet Pro M1536dnf Multifunction...
When I receive a fax, it prints out perfectly. When I make a copy or scan to fax/email, the page has multiple black lines running down the length of the page. I have recently replaced the drum and the...
As the fax receives and prints incoming faxes ok then the print engine is working ok. the fact that the problem arises when copying or scanning indicates the problem is with the scanner or software that controls the scanner.
First clean both scanner glasses and the white area (white reference) under the doc feeder. When you are happy all is clean, follow the following instructions:
Press menu, * 2864 within 3 seconds. the display will show "Maintenance"
now press 55. The scanner will initialise and go back to "Maintenance"
now press 99 and the machine will go back to the default screen showing date and time.
Now do a copy. if you still have the lines or its all black then you will need a new contact image sensor. If all is well then that was a good cheap repair.
May 26, 2011 | Brother MFC-7340 All-In-One Laser Printer
We have a Brother 4100 Fax Machine. When we send a fax or make a copy, there is a black bar about 2" wide that shows up the length of the page. It does not appear on incoming faxes. I believe it is...
Make sure the **** glass is clean, use a micro fiber cloth to wipe the debris/old toner or white out off the glass. restart the fax machine. If it prints this black line from a copy and it is 2" wide after you have cleaned both the glass and the white reference bar, most likley the scanner itself has failed. for further assistance.
Jan 14, 2011 | Brother IntelliFAX 4100 Laser Fax
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
White "Stripes" across page
May 14, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Canon FAX-B820 Plain Paper Bubblejet Logo
145 people viewed this question
old marine
old marine
