Question about Jl Audio 12W3 Car Subwoofer
Sub works but doesn't sound right
My car sub works when i turn up the stereo, and it still vibrates like it is hitting hard but has no sound like it used to. i don't think it is blown though because it doesn't make that rattling sound like when i have blown a sub before?
Hey been there before u need new rca wires form ur radio to the amp.
Posted on Jan 17, 2009
1000 watt 2-channel Pyle PDGA240 Gear X Series
Make sure that the gain setting on the amp is turned up high enough on the sub's amp.
Aug 26, 2013 | Car Audio & Video
Hit bump and subs and amp wont work
Loose wire or connection is causing stereo to short out, Check all connections including amp,Stereo,Speakers and make sure nothing is touching places it shouldn't
Jul 29, 2010 | Jl Audio Class D E1400D Car Audio...
Subwoofer rattling.
Make sure your sub is securely screwed to your box, boot build, whatever you have it sitting in. Remember subs are made to vibrate when working, check your screws are tight.
Sep 07, 2009 | Car Audio & Video
Only one sub hitting
you most likely have them wired out of phase. Try reversing the wiring on only one of the speakers.
Apr 23, 2009 | Rockford Fosgate Punch 401S Car Audio...
Subwoofers not hitting as hard as it should.
First thing when your care is idleing turn you system up and watch your rpms. Is it going all over the place when you turn it up?If so your altenator isn't putting out enough power.Might be able to fix that problem with another fadar cap. You should buy the digital read out for your cap to see how bad its draws power.They have ones that will mount to the top of your fadar cap.You can all so get a bigger altenator.Also check your ground clean it along with other connection batter,both sides of you fuse and any other connection,bass will loose all bolts/screws over time because of the bass,even to sub have had one work its way off in a year once.
Mar 03, 2009 | Car Audio & Video
10 inch subs need help
It sounds like the wiring either to the amp or to the subs is put together wrong. This can be because you have them setup in stereo but have the sub on bridge mode or vica versa. This can also be from how you ran the audio input wither from speakers or rca..either wired wrong or the switch for the two options is wrong. Also make sure your gain is turned up. Sound also depends on what kind of box it is in. It HAS to be in a box.
Jan 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Bose Acoustimass power
I have the same problem TOO!#$#@% Anyone out there?
Nov 08, 2007 | Bose Acoustimass 5 III System
Jl Audio 12W3 Car Subwoofer Logo
346 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
