Question about Remington Titanium Microflex R-950 Electric Shaver
Slipping Head After the first cleaning, one of the heads slips, starts making a grinding noise, and doesn't turn. It's always the same head, and needs to be pushed down to seeminly make contact with the shaft inside? This has happened on two seperate units.
SOURCE: my R-1000 remington head broke
You can order a replacement from - for $8.95 plus shipping
Posted on Aug 08, 2009
Testimonial: "thank you very much for the info."
  • 1535 Answers
SOURCE: The triangular fixing socket in the shaver head
You did not mention your shaver model number so I can not address your specific model. But, you will find many of these type parts a You will need to know your model number.
Posted on Feb 26, 2010
  • 1535 Answers
SOURCE: top piece that holds the shaving heads (protective
the protective cap is not on the shaver when it is placed in the cleaning and charging machine. Perhaps you mean the 'head holer' You will find parts for model R-9500 at See links below for the head holder and the protective cap
Posted on Nov 23, 2010
  • 1535 Answers
SOURCE: remington 5130 battery is fully charged and when
It sounds like either the heads are packed full of hair particles and the blades can not turn OR one of the blades has been damaged and is causing it to lock up.
Try removing all of the blades and cleaning them thoroughly and also insoect the blades, particularly the one that moves when you turn it on
If replacements are required, you will find them at See link below
Posted on Dec 08, 2010
  • 1535 Answers
SOURCE: The cutter head will not stay on razor, when
This problem is because the shaver has not been thoroughly cleaned. There is a build-up of hair particles where the screen snaps onto the shaver which is preventing it from latching into place. Clean it thoroughly and it should be fine
If you are certain that it is thoroughly cleaned and still have problems, your screen is worn and will need replaced. You will find replacements for model F4790 at See link below
Posted on Dec 16, 2010
  • 1535 Answers
SOURCE: are the heads suppose to turn. I cleaned the
The round discs that touch you face are not supposed to turn. Only the blades on the inside turn
Posted on Dec 31, 2010
0 characters
1 Points
Philips pt920 makes clicking noise but doesn't 'spin'. When turned on there is a clicking noise. The 3 rod like things which normally spins no longer spins. The head should be working as its removed.
If you flip the head up and the shaver will run without the blades engaged, there is a problem with your blades. The may be installed incorrectly or damaged. Check that they are installed correctly using the video below
When removed, each cutter should turn freely inside its corresponding comb. If one or more do not turn, there is damage and will need replaced. Replacements for model PT920 can be found at at the link below
Sep 11, 2016 | Philips Shavers
Remington F5790
Get a toothpick and clean around the where the head slips in. the build up does not let the head seat.
May 31, 2012 | Remington F5790
I have a norelco arcitec shaver and the heads no longer turn. I haven't had it that long so of course very disappointed with the razor. I would like to take it apart to clean it, thinking there may...
You are problable correct in thinking that the blades are clogged up. Unfortunately, you are also correct about the terrible design. The blades on Arcitec models can not be removed from the head assembly for cleaning
complaints can be made to Noreclo at 1-800-243-3050
Replacement head assembly can be purchase from See link below
May 10, 2011 | Shavers
How to clean a remington EP6010 epilator?
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual:
Feb 28, 2011 | Remington Shavers
The cutting unit will not turn or when it does it is slow and the unit makes funny noises
The blades are probably clogged solid with a pasty mixture of hair particles and skin oils. You will need to try to clean them but it is difficult on Arcitec models because the blades can not be removed from the head assembly
If replacements are needed, you will find them at See link below
Nov 17, 2010 | Norelco Arcitec Electric Shaver -...
Norelco 5865XL: Suddenly the blade heads are making excessive
It sounds like one of the heads is damaged. You will need to replace it. These come in sets of 3 combs and 3 cutters.
Jun 15, 2010 | Norelco 5865 XL Electric Shaver
My friend has an Andis master adjustable and the little bracket that holds the two piece head will not vibrate back and forth like it shoud (seems to be stuck) Thanks Ed
I just put the tow piece head back on,oiled it good and turned the adjustment screw on the right side of the clipper to the right until it quit making noise and the clipper head started to work just fine. oiling is important. Ed
Feb 16, 2010 | Andis 01690 Hair Trimmer
Remington Titanium Microflex R-950 Electric Shaver Logo
23 people viewed this question
Top Remington Shavers Experts
Robert McClure
Are you a Remington Shaver Expert? Answer questions, earn points and help others
