Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
Geltab not coming out of door
I have used different types of dishwashing soap and a lot of the times the geltab etc will not come out of the holder. I have to wash the dishes 2 or 3 times to get the soap out of the container.
SOURCE: Dishwasher leaves a fine black sludge
I work in a hospital and have seen this problem with our scope washers (a very sophisticated dishwasher with lots of safety features) and it turned out to be a faulty pump motor.  Some pumps have black ceramic magnet in them and if it cracks it will breakdown and mix in with wash water creating a black smudge on everything with bits. Just as you described.  Unfortunately, I have never taken a part a dishwasher motor so I don't know if it's the same type of motor.
Posted on Oct 11, 2007
  • 1314 Answers
SOURCE: Problems with my dishwasher
You need to replace the dispenser or possibly the wax motor on the dispenser. I would be more than happy to help you. But need to know the brand an model # so I can make sure that I give you the proper advise.
Posted on Jan 01, 2008
  • 105 Answers
SOURCE: Have the Kenmore Limited Edition
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Posted on Feb 02, 2008
ngfam1
  • 639 Answers
SOURCE: GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dear friend,
ngfam at you service! happy to assist!
Sprayers or sprayer clogged and or pump weak!
Better call service
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 29, 2008
SOURCE: Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Posted on Jan 09, 2009
Soap dispenser cover latch will not stay in the hole. So now the soap holder will not stay closed.
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Jan 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
How can i use the liquid soap inside the dishwasher
just fill the same holder that you would use for powder.
Dec 17, 2010 | Dishwashers
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
There is soap left at the end of a cycle from the dispenser. It is trailing down the door and standing in a puddle at the bottom of the dishwasher. The soap that is not in the trap door seems to wash...
Try different detergent types--liquid instead of powder, capsules instead of liquid. Don't put large dishes near the door that might block spray. Check the spray holes in the spray arms for blocking.
Sep 18, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Soap won't dissolve in dishwasher
I had the same problem and my wife fived it by unsticking a valve to the left side of machine in front lets water in she poped it open and dried soapm came out restarted and now works fine.
Jul 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Soap not used
There are 2 causes for this.
The first is most common, and easy to check. If you have something blocking the door from opening at the proper time, it will never release the soap, and by the time the cycle finishes, it will be locked again. Make sure nothing tall is near the front of the load, especially on the soap dispenser side. Try running it on normal cycle with the dishwasher empty (even take the racks out if you can) to see if it works with no obstructions.
The second cause is much less common, but harder to check. A mechanical failure inside the door could be preventing the trigger from opening the soap door at the proper time. For this, unless you are mechanical, it's best to call an appliance repairman. It requires taking apart a portion of the front door assembly.
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Soap left in dispenser. dried soap on dishes and siverware
After the fill cycle, check to make sure you have enough water in the dishwasher to wash effectively. You may need to have your fill valve replaced. You can test this by adding perhaps a liter of water to see if it makes a difference
Feb 25, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Soap hardens in the dispenser and dishes don't come clean
Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Soap not dispensed and dishes not washed
water is getting past the gasket during the start up cycle. by the time the door opens, the water has caked up the soap. also, its not clear when in the cycle the door is opening.
try using liquid soap.
also, take a peek just after the machine has finished filling and starts washing to see if the door is opened on the soap disp.
good luck
mark
Dec 19, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
22 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
