Question about Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA Receiver Car Video Player
White Screen The head unit does not display anything when powered on. The "ALPINE" intro tries to come on, sorta halfway but with much of the pieces missing and most of the screen is white; then the whole screen fades to white. Everything else seems to function correctly. Tried resetting the unit but that did nothing.
  • 1 more comment
  • scratcherr Dec 23, 2007
    the same as thaphenoms problems abve what is the solution???????? anybody???????
  • Bromantx Jan 20, 2008
    My unit does the same thing. Turn it on. Alpine shows then it starts to fade into nothing. I can still use the functions by memory but this sux, the bulb cant be blown i only used it a couple months. Any suggestions email me katytxblkm@yahoo.com
  • Hashim Abdullah Jan 20, 2008
    Anyone who still has this problem should send their unit to Alpine for repair. The LCD screen is bad and needs to be replaced. I've since upgraded mine to the IVA-W205.
  • 3 Answers
  • you need a new screen and a service manual to repair once you get one send me a copy buddy
Posted on Jan 02, 2008
SOURCE:
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
Alpine CDA-9835 Head Unit
it may have a connection problem(flexible strip) to the PCB that has dislodged, or the display itself has developed a problem. Couple of questions, is it entire characters that are missing, or parts of same. Is the unit still operating normally?
Hit me back here and we shall get to the bottom of your problem.:)
regards
Graeme
Feb 14, 2008 | Alpine CDA-9835R CD Player
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work correctly.in a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
Display malfunctions/no working functions
Remote turn on lead shorted to audio intterupt lead? I would just hook up power and ground to the 9833 and see if problem goes away. If not is must be internal to the 9833. If problem goes away i would double check wiring. Good luck that is a sweet cd player.
May 07, 2009 | Alpine CDA-9833 CD Player
Connect alpine 7874 to alpine powered sub
You need to run the RCA cables from the head unit to the sub for the audio signal, and possibly a turn on wire (the blue one on the back of the head unit), unless the sub has an automatic power feature.
The sub also needs power and ground wires attached, but those do not connect to the head unit. Power should be run directly from the battery with an inline fuse, and ground should go to the nearest good ground point (Trunk latch, seat bolt, etc).
Mar 20, 2009 | Alpine CDM-7874 CD Player
Alpine CDA-9886 error 1
Try turning off the password lock or password if you have one. That fixed mine. I had an identical problem.
Jan 10, 2009 | Alpine CDA-9885 CD Player
Not Working
My only suggestion is to check your wiring.
Be positive your accessory wire [red wire] is hooked up to the correct wire from your car's wiring harness.
To be positive this is the problem, connect both the red and yellow wires [accessory and battery] coming from your head unit to the battery wire from the car's harness temporarily.
Do not, however, leave your head unit wired this way. It will never shut off and drain your battery.
If your head unit still does not turn on, and you say the fuse is good, you most likely have a bad head unit.
Most head units now have a fuse in the back next to the wiring harness as well.
Don't forget to check that one as well, in case you missed it.
Dec 16, 2008 | Alpine CDA-7863 CD Player
Inconsistant Switching of Alpine MRA-F350 Amp
try and unplug the audiovox unit and check if problems still exist. and what swithes on what unit are you talking about? this kind of sounds like a wiring problem.
Nov 21, 2008 | Alpine MRA-F350 Car Audio Amplifier
Car Audio & Video Logo
1,064 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
