Question about Dishwashers
Dishwasher door won't stay up, cable disconnected
Ge potscrubber 800 dishwasher (GSD 800t-55ba) door became heavy, as if the spring broke, noticed cable loose on lower right of dishwasher. How do you re-connected the cable? Where can you find a diagram for the door assembly?
2 Suggested Answers
SOURCE: The GE Potscrubber 600 door feels too heavy -
The door has a dual spring link with eyelet hooks at each end. I have the same problem. You can access it by loosening the four screws of the bottom panel. The eyelet wire is about 6 inches in length at each end of the dual springs. You run the wire around the 2 nylon wheels located at each end of the unit's bottom. They hook up to the small protrusion at the very end of the unit.
Hopes this helps.
Posted on Nov 15, 2010
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
Hello. I have a GE Potscrubber 600 dishwasher. The soap dispenser will not close. This seems to be a common problem. Any help would be great, thank you.
Main detergent cup won't close on GE Potscrubber 700 GSD700.A workaround is to add the additional detergent with rinse aid 18 minutes intothe wash cycle. To repair, switch off power through circuit breaker. Set timerknob to 12 o'clock. If the detergent cup lever spring opens the cup after it isclosed, remove screws on panel that holds detergent cup and remove the panel upand out of door. Remove timer cover by moving it right and pulling up to exposetimer, see photo 1. _1909.jpg If a spring is loose, it can be reattached as follows.Remove two screws that hold timer, then remove timer. Do not remove timer knobfrom front of GSD700 because knob is designed for removal from rear of panel,after the timer is out. If spring attachment point broke off, reinforce it withepoxy (JBKwik), see gray cone upper right of center in photo 2. _1910.jpg After epoxy cures, drill and tap a hole for a metric 3 - 0.5mm-8mm screw (4-40 may also work). Install spring between new screw anddispenser linkage and tighten screw, see photo 3. _1911.jpg Install timer, jiggle knob so it engages timer and securetimer with two screws. Pull dispenser lever down to make sure it moves andsprings back. Replace round switch and cover. Install white cover with leverextended through it. Install cover screws, close soap door, and rotate timer,soap door should open after about 90 degrees of rotation followed by rinse aidactuation.
Oct 24, 2010 | GE Dishwashers
The GE Potscrubber 600 door feels too heavy - some hinge/cable/spring seems to have failed. How do I diagnose and fix it.
Hopes this helps.
Jun 04, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
The spring on the door broke (loud sound) and now the door is heavy and doesn't stay up unless we latch it each time. How do we find instructions for installing a new spring?
its hard to find instructions but go to sears parts direct and order parts .you will see the location of the parts and a image that should put uyou in the right direction
Mar 02, 2010 | Frigidaire PLDB998A Built-in Dishwasher
GE GSD900L-02 Door spring cable broke
Get 2 of the same springs part # PS259673
DOOR SPRING (YELLOW) (Heavy Duty Door Spring)
Sep 12, 2009 | GE Dishwashers
GE Potscrubber 800 Leaks
See if your parts store can mic the oring and match it to one
May 01, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
