Question about GE JGBP28 Gas Kitchen Range
GE XL44 oven will not work.
Glow light turns on but flame does not ignite. Oven is about 10 yrs old.
    Habit-Forming:
  • 171 Answers
Replace the [Glow light] the ignitor same thing, you see the ignitor most be super hot to open the safety valve.I have fix that problem many times before, very comment problem.
Posted on Dec 07, 2008
I have a GE True Temp XL44 oven the stove burners work fine but the oven will not light. When I turn it on the oven, I do not smell any gas. What is the problem and how do I fix it?
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Feb 13, 2011 | GE Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
Oven won't work
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Aug 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP34 (XL44) oven won't light
Look at Lower Igniter
Check these two Sites here:
http://www.fixya.com/support/t141325-ge_xl44_range
and
http://www.fixya.com/support/t130970-ge_xl44_gas_oven
I just got this same problem today. Will do the same thing as these guys said in the morning. Good Luck.
Love these fix-it sites.
Jan 10, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE XL44 Range
The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP28 Gas Kitchen Range Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
