Question about Acer Aspire 5610-4648 Notebook
Switchon laptops processor doesnot running no indication screen
When switchon no response in screen ,processor doesnot running if we try morethan 3 to 5 times then it starts..how to recitify problem??
  • Acer Master
  • 4,806 Answers
Need more info please
Posted on Nov 13, 2008
My laptop doesnot gets on only power n touchpad light turna blue nothing is displayed
I would try to plug in a monitor to the laptop. If the monitor works then you know that the LCD screen or LCD inverter is bad. If the monitor does not work the it could very well be you intergrated graphic is bad. Maybe also try to push the function button to switch from the laptop LCD to an external monitor a couple of times and see if anything happens.
Sep 29, 2013 | Samsung Laptop R480 Intel Pentium...
Board runs shows to be on runs but no beep and no display. No beep even when processor or memory removed.
The problem is in the processor or in the board to check first change the processor sutable for the socket and switchon the computer still the computer doesnt work check the secondery power supply thats four pin from the smps to the motherboard check all the FET and the capacitor in the powersupply also the 32khz crystel and the 14.182khz crystel and the clock ic
Mar 29, 2011 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Vostro 1510 no diplay on screen. All indications lights are blinking
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Computers & Internet
Asus G73 won't Turn on. The power button gets no response though the AC adapter's indicator light is green.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 08, 2010 | ASUS G73JHA1 Notebook
Acer Extensa 5620Z freezes after a few minutes and the HD indicator goes out. The processor gets very hot
Hi
Thnak you for your query
Please try the followng
1) Switch on laptop
2) It will say something like press X to enter setup where X=F2, del or esc
3) This will present you with a blue and white screen called the Bios screen, leave it on that screen fro about a hour, then try moving the cursor keys to see if the bar moves around. If the bar doesnt move this indicates your laptop is overheating and you will need to book into a reputable PC shop for repair
Regards
Shauqat
Apr 14, 2010 | Acer Extensa 5620 Notebook PC
I replaced the 3 capacitors now there's just bright white screen
Open your monitor back up and look for unplugged connectors, especially the one to the back of the LCD. I had this same problem with a HP F1703. The owner whacked it so hard when the backlight stopped that they dislodged the connector.
Feb 27, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Vaio laptop processor not running?
if u can easily access the |apt0p mem0ry strip, try t0 rem0ve themem0ry 0n the s|0t and wipe and c|ean the br0nze meta| and put it backagain 0n the sl0t pr0per|y.
|et me kn0w
http://www.fixya.com/support/t1544574-power
Jan 15, 2009 | Computers & Internet
Startup problem
that wouldn't mean the processor is off, it means there is a problem with the motherboard. I don't know the exact problem with the motherboard. but it could be something wrong with the processor too. but I suggest you take your PC to like Circuit city, best buy, or your local computer shop to have them take a look at.
Jun 10, 2008 | Fujitsu LifeBook S6240 Notebook
Acer Aspire 5610-4648 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
