Question about Singer CE-100 Futura Computerized Sewing Machine
Will not sew
When I am trying to embroider I send the image from the computer to the sewing machine and the message on the computer is: machine has paused. Press start to begin sewing. I press start but nothing happens! help!
Make sure your machine is on a level table or base. I had the same problem with my CE-200 and as soon as I moved the machine to a level table the start button worked.
Posted on Oct 11, 2016
Try turning off the machine and turning it on again. Sometimes this will reset it so it will work. Also, make sure the embroidery foot is in the down position; the machine will pause and "beep" if you haven't lowered it. Hope this helps!
Posted on Nov 04, 2007
SOURCE:
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
When I start to try to embroider the red light just blinks and I can not send tothe machine
you might try youtube for video's on embroidery
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 02, 2012 | Sewing Machines
Does the futura software from compucon allow you to wind the design forward so you can upload the design to the machine, and can continue embroidering the design to complete it. Reason why is had to...
You can skip color blocks that you have already embroidered. When you get to the one you were working on when the machine was turned off, send it to the machine and use the needle down button to advance the design to the point when you stopped. Then you can hit the green button and proceed.
Dec 04, 2011 | Singer CE-200 Quantum Futura Computerized...
I have a janome 9000 what is a scan & sew
Scan 'n Sew is hardware used to transfer embroidery designs from your computer to the machine's card so that you can embroider that particular design. I have one and love it. It will send a template to your printer as well as the design to the card. It has other functions that I don't use because I use another program to edit designs (Embird).
Jan 04, 2009 | Janome Memory Craft 9000 Computerized...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Beeping lights when trying to sew
Look at the back of the needle threader. There is a buttonhole lever. Pull it down and push it back to the top. The machine gives a warning message if the lever is down and you wants to sew or embroid.
Good Luck
Dec 01, 2008 | Singer CE-100 Futura Computerized Sewing...
Cancelling a transmission
You must remember your machine acts like a printer. It will only accept another pattern once the current one is finished. A common fault amongst many users are that they send another pattern while the machine is busy with the current pattern. The correct procedure would be to cancel the current pattern, before sending another one.
You do this by clicking on "exit". Another window will open and ask you if you want to terminate the current transmision to the machine.
If you send one pattern over the current one, your machine is capable of queing and the only wat to resove the issue is by switching the machine off and leaving it off for 60 seconds and resend your nwe pattern
Hope this help you
Dec 10, 2007 | Singer CE-100 Futura Computerized Sewing...
Auto punch unable to transfer a logo and embroider as shown on the picture
dear Ralitsa,
Autopunch is a very basic digitizing program and can not handle jpg images that has a lot of detail and colours. It can can handle simple clipart images with ease. If you want to embroider the logo ask someone who has a proper software program to digitize the logo for you and you should be able to to do the embroidery on your machine.
Regards
Dupina
Dec 01, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
123 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
