Question about HP Office Equipment & Supplies
New printer purchaced 10/10/08 will not print a envelope.
  • 1,124 Answers
You have to set the printer to do that
Posted on Nov 12, 2008
I am trying to print one (1) envelope for mailing on my mp 150
Open microsoft office and click on new office document then choose blank document. Click on mailings at the top of the screen and then choose envelope. Enter the information you want to print on the envelope on the screen and then click file and print to print it.
You will need to load an envelope in the right way for your printer to print on that instead of paper.
Oct 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
I was so pissed off that so many on the web had this same problem that I spent many hours trying to get it to work. I am sure that this is not how it is designed to work but my envelopes got printed.First I went under File, Print, Properties to Page Set-up for envelope #10. I also ********** print colour images in black and white which someone else had suggested- although it might not be necessary. I selected quick print but normal should probably work too. I then closed out these two windows. Then under tools, I selected Letters and Mailing, then envelopes and labels, typed in the addresses, went under options and changed the feed from automatic to default tray, which automatically changes the feed method to the 4th one out of 6 which wasn't what I wanted but ignore it. Check off face up. Putting the envelope into the printer was bizarre- it has to be inserted very far into the printer until only 2-3 inches of the envelope stick above the horizontal surface of the printer. It must be inserted into the middle of the paper holder, until it is just 2-3 inches sticking up, and then slide it all the way over to the right where the printer indicates the envelope should be- nice and straight against the right margin. Do not use the movable paper holders that they suggest you swing over to the right to hold your envelope- or printing won't occur for some odd reason. Press O.K. on envelopes and labels and then press print. Good luck- it worked for me.
Jun 01, 2009 | Office Equipment & Supplies
Epson Stylus NX400 While printing envelopes, I keep getting a black ink blot on the bottom right hand corner of the envelopes. It happens to about every 1 out of 4 envelopes. I printed the return addr
Envelopes can give all sorts of problems Back corner is flicking up. Try rolling the envelopes in the opposite direction to the "bowing" as they have been through machine once.
Apr 22, 2009 | Epson Stylus NX400 InkJet Printer
Envelopes jam in my hp 6940; paper sheets feed fine
I have had varying success with envelopes. Can you feed in the other way round? Sometimes different envelopes perform better. The peel N seal can be very difficult
Apr 10, 2009 | HP Deskjet 6940 InkJet Printer
Cannot print envelope on MX310
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Printer Driver Settings:
1Select Envelope in Media Type.
  1. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
  2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printing envelopes on a hp laser jet p215dn
Please load envelops from tray 1.
When printing from application, just Ctrl + P and OK.
- Nikhil
Jul 10, 2008 | HP LaserJet P2015dn Printer
Envelope Feeder is not accepting the command
> Home > Support & Drivers > Knowledge Base
Solution --> Phaser 4400 Printer: Printing envelopes
Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
Guidelines for envelope printing
  • Use only paper envelopes.
  • Do not print on the back of the envelope.
  • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
  • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
  • Envelopes may wrinkle depending on weight and stiffness of the envelope.
Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
  • Select faceup.
  • Clear Clockwise Rotation.
  • Select the feed method with the image centered and the stamp on the envelope to the upper left.
caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
  1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
    • Place the side to be printed faceup.
    • The top of the envelopes should be toward the left of the printer.
Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
Dell 720 Printer not printing envelopes.
I got the printer to print envelopes again. I completely uninstalled the printer, then reinstalled it by simply pluging the USB connection in. After I had first uninstalled it after the envelope problem started I had been using the 720 printer CD to reinstall it, and it still wouldn't print envelopes. I looked for and found the printer installition instructions and saw that I didn't need the CD to install it. (It was causing a software conflict). The Dell 720 Printer came with my Dell Dimension E310 PC new and the printer software was already on the hard drive. All I had to do was plug in the USB cable, and the printer was up and running like new again. Don't forget, if you don't want Dell to monitor your printer use, DO NOT check the box to allow that when it comes up during installation, other wise you'll get that icon showing up. Hope this helps. Chuck
Jan 09, 2007 | Dell Inkjet 720 Printer
Ben Johnson
