Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneersd533hd5 when i try to turn my tv on the standby light goes to green and then back to red. The tv will not turn on.
(3) 4 amp 150 volt fuses (slow burn), and (2) 10 amp 250 volt fuses (ceramic), all replaced. $5.50 worth of fuses DID THE TRICK. Radio Shack has them both. If you can't find a 4 amp 150 volt, 5-6 amp up to 150 volt fuses work just fine!
Posted on Sep 03, 2007
  • Rebecca Aug 08, 2011
    Had same problem just made the trip to radio shack and walah! tv works great thanks so much for advice
Had the exact problem on 11/14/06. Ordered a power supply board, which was $300+, got it in and when I went to replace the part, found that the old part had a blown fuse (a lot cheaper). Of course if I had put in the new part it would have fixed it also. CHECK THE FUSES IN THE MIDDLE CIRCUIT BOARD (there are 3 boards).
Posted on Nov 21, 2006
SOURCE:
Light on beko lcd tv goes from red to green and back to red without coming on
Main board fault. Shorted component/s on this board. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 05, 2014 | Beko 17WLB450S 17 in. LCD TV
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
Thomson 27 LCDB 03B
when i turn on my tv the light turns orange green for a few seconds.
Jan 15, 2010 | Thomson LCDB 03B 27 in. Television
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
Jun 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Stuck in standby
Sorry about that. When the tv goes bad like not turning on, the green light will blink, and goes right back to red standby light while the dtv letters will briefly show on the lower right of the tv screen, then go back to blank screen. The tv will need to be taken to an authorized service center for repair. Common causes are a bad inverter/power supply, power control board, or circuit board.
May 16, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
163 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
