Question about Lexmark Office Equipment & Supplies
I can not get my Lexmark X7550 printer to print.
    Genius:
  • 1,124 Answers
If you already have your printer installed do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Nov 12, 2008
My x7550 wont print pictures.....says its printing and ink level goes down, but photo paper comes out blank
It could be that your cartridges need some cleaning. From the printer operator panel, scroll to the Maintenance menu and select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridges nozzles and clean them.
After doing the clean cartridge function, try to print another photo to determine if the problem is fixed.
Hope this helps.
Apr 30, 2012 | Lexmark X7550 InkJet Printer
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
Can a lexmark x7550 print to a mac?
Yes, the Lexmark X7550 support Mac & Windows too. You have to install the respective drivers versions for your Mac versions.
You can download the Mac OS versions drivers @ http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X7550#2
Make your Mac OS selections "Change OS" to proceed in downloading the correct Mac drivers for your System.
Hope it helps.
Jun 24, 2011 | Lexmark X7550 InkJet Printer
Cannot print to lexmark x7550 printer. it seems that printer is able to scan but not able to print. already installed the software, but when connecting the printer to the computer with windows 7, it...
Try to use the Windows 7 driver from the Lexmark website. Uninstall the existing driver from your computer first. How to Uninstall Lexmark Printers. Reboot pc when prompted. Then, check if your Windows 7 is running on 32-bit or 64-bit system type by going to the Start menu > right-click on Computer > Properties. Take note of the System Type.
To reinstall the driver, use the following links below: - Lexmark X7550 Driver for Windows 7 32-bit - Lexmark X7550 Driver for Windows 7 64-bit
May 25, 2011 | Lexmark X7550 InkJet Printer
I have a LexMark x7550 all-in-one printer, model:4429-W22, serial #: 01360113314 2007/09. Printer will not print internet download or regular documents. I unpluged the printer and rechecked connections,...
Please go to run and enter "devmgmt.msc" you will get device manager, Remove all of the Universal Serial Bus from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the all in on printer and install the software properly.
Aug 07, 2010 | Lexmark X7550 InkJet Printer
I want to know what ink does it need. What to buy for my Lexmark X7500 series
I have the same printer and I go to Office Depot, the cheapest around, and you get rewards. Lexmark 41 Print Cartridge is the color and Lexmark 42 Print cartridge is the black.
May 15, 2010 | Lexmark X7550 InkJet Printer
I have a X7550 printer and I can't get it to print
please confirm which OS is on your laptop, and run the driver for that OS, you may read this up
http://www.lexmark.com/publications/eng/x7500/index.html
Mar 16, 2010 | Office Equipment & Supplies
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
