Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Carpet brush does not work.but if i lay it on its side it works. i think it a switch but i cant get the handle apart to check it bissell 6405 vacum
  • 107 Answers
You need a new belt.
Posted on Dec 08, 2008
Why doesnt bissell carpet cleaner brush turn properly
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 06, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell carpet shampooer will not dispense water or cleaning solution, nor is the "flow indicator" spinning
most of the Bissell carpet cleaners that have the water heating feature stop pumping water at one time or another. Make sure the belt is still on the pump and if it is then the problem is probably in the heater core in the handle. Hard water deposits plug the tiny little water ways inside the heater core. Pull the heater core and take it apart and clean it with a strong scrub brush and I think vinegar works for cleaning I was told. I just use soap and a brush. Then flush all your lines with hot water. The cause is from hard water deposits or leaving the soap in the cleaner after you use it. Both will stop it from pumping water
Apr 29, 2014 | Bissell 1698-1 PowerSteamer ProHeat Plus...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Brush will not turn
The most common problem is the handle isn't screwed in tight enough when the machine was assembled. Try tightening it down all the was and the electrical connections will then seat properly.
Jul 05, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 9400 Carpet Cleaner
I assume you checked the belts to see if any cogs were stripped of of the belt. If ok, then I wuld suspect the brush roll motor, it is any inexpensive part and doesn't take much for it to fail. Undo the top so you can get to it and unhook the belt and see if it still shuts of, if it does, ten replace it, it it doesn't, then there is a problem with brush rolls or belts.
May 13, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
42 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
