Question about Xerox DocuColor 12 Printer
Erox dc 12 error 9-342
I have changed the btr assembly i have also changed the btr clutch in the back of the copier.
The code keeps returning ??
Help
    Problem Solver:
  • 5 Answers
In Spanish
Quita la tapa de el drawer
Obseva la media lunita de el 2nd BTR Black & yellow Cheat el sw de la puerta Si no hace el intento de girar . Quita la tapa posterior y observa si gira el motor principal y el motor de el cilindro si no giran tienes un problema en la AC driver 5Volts o en los 24 volts verifica tambien los fuses de la PWB de interconexion y de la Ac driver suerte
Posted on Nov 17, 2008
Its the first time I post here. I have a problem with a Xerox Docucolor 12. When I turn on the machine, the main motor doesnt run and gives "9-343 error" on display.
Some weeks ago I had some similar errors (9-342,9-344) but machine works after turn off during some seconds. Other time I had to enter on Component Control (DC330), enter "9-215" and got change Low value into High value.
But this time I got "9-342" error, I got to put High value on DC330 (9-215) but I couldn't with "9-343" error. I cannot change L into H (enter codes 4-007, 9-059 and 9-215).
I have checked IOT Drive, and some cables,... As fas as I know it has some to do with IBT or 2nd BTR...
Anyone has some idea? Who can help me? Thanks!
Posted on Jan 20, 2010
Error code 9-343
try changing the FD interlock SW. Also check if the gears on the 2nd BTRare having good contact with the clutch. If still no difference, replace the 2nd BTR clutch. If you are unsure how to check/fix this issue please contact your local repair shop or manufacturer technical support.
Jun 11, 2014 | Xerox DocuColor 12 Printer
Error Code - 9-343 on Doc 12
it seems you have problem in sensor ...........
change the FD interlock......
Oct 23, 2008 | Xerox DocuColor 12 Printer
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
Error 9-358, Por favor si pueden enviar respuesta en español. Gracias
Problem seems to relate to the BTR Cam Sensor. The area around it might covered in toner and if so, you could try blowing out the sensor using air. Might also be due to a bad, dirty or full 2nd BTR assembly. Empty the waste from this. Do NOT hold the plate too far open otherwise it may lead to problems in the future. Clean it thoroughly before replacing it. It is also possible that the 2nd BTR cam might not be seated properly into its home position. Also, the clutch could be bad.
Jun 11, 2009 | Xerox DocuColor 12 Printer
Dc 12
clen drum charge grit, ibt assay and 2nt btr unit...
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
Error code 9-342 at start up / docucolor 12
That is a BTR contact failure. The Bias Transfer Roller is not making proper contact.
Most likely time for the BTR assembly to be replaced.
Apr 01, 2008 | Xerox DocuColor 12 Printer
Error code 9-343 for Ducocolor 12
That is a contact failure on the BTR roller. It is the larger black roller inside the left side door. It may just have a dirty contact, or may need to be replaced. But for some reason the machine is not seeing good contact to that roller.
Mar 21, 2008 | Xerox DocuColor 12 Printer
Solving problem of system error
That is a contact issue with the BTR roller..
Mar 18, 2008 | Xerox DocuColor 12 Color Copier
Error code
The BTR Retract CAM Sensor is either defective or dirty. Before replacing the cam sensor, you may try just cleaning the drive clutch for the BTR assembly. If it's very dirty, that may be your problem. Average price for this part is around $20.00. This varies depending model of printer.
Jan 30, 2008 | Office Equipment & Supplies
Error Codes 9-343
That means , second BTR is not in contact with transfer belt. Open front door and pull out paper transport and check that is everything OK with black roll and her assembly.Check sensors for dirt,and gears for damage.If You have used one ,replace it.
Nov 10, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
1,106 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
