SOURCE: new wireless network - now my airport express and airtunes does not work
thanks so much - vey helpful!
SOURCE: Apple Airport Express not working
Throw the device out of the window, the apple folks are terrible and liers they mislead us into buying this device and it is not working with most Vistas.
SOURCE: New Apple Airport Express Base station blinking amber light
Using the Airport utility on your macbook (located in your Utilities folder) will tell you what the conflict is.....most likely you have DHCP issue or the network is at the incorrect setting.
The wizard in the utility will tell you what you should fix.
SOURCE: I can't connect apple airport expresses with a siemens 587 route
When doing this keep your password to 13 characters as different companies apply different defaults to make up the required 13
SOURCE: I use a time capsule
Plug them directly into the Macbook Pro using an ethernet cable and set them up as extended networks using the Airport Utility.
Wait until you get a green light, and you should be all set!
For audio and PA system expertise, and great AA Speaker Tapes, CDs and MP3 downloads, visit my website at www.rexark.com
