Yamaha 88 Key Portable Grand w/stand Logo
WENDY CAMLIN Posted on Apr 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DGX620 Have lost half my screen
Anonymous
Level 3:
Genius:
  • Master 1,212 Answers
  • Posted on Apr 11, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1212
Questions
0
Helped
469580
Points
2874
If the backlight is on and just half of the display data is there, it is probable the conductive strip has come away from the display or the contact portion of the board where the conductor strip lays on the circuit board.
If it is under warranty, contact Yamaha. If it not under warranty, you can try to fix it, but once adhesive lets go, it is diffeicult to get them to premanently readhere. A repair shop that is Yamaha authorized is able to get the New parts from Yamaha that fit.
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Only blue light with blank display on power on
Dear Joseph,
I had similar problem with my DGX620. In my case the display sometimes got blue and sometimes worked fine. The cause was a bad contact of the display flat cable.
I opened the DGX620 and then I cut a small piece of plastic film (35mm negative) with exactly the same width of the flat, disconnect the flat cable and then reconnected it using the film on the other side (non contact side) to increase the pressure and guarantee a good contact. No more problems from nov-2012 till now.
Good luck !
Paulo de Tarso (Brazil)
Mm6 dark screen
only few technician could do some repair with the screen card or the connections fron screen to cards very complicated usually the screen goes off totally only few could do it luckily by chance.
you need to change the screen i suppose
2answers
The LCD display on our yamaha DGX620 has disappeared: it lights up but there is nothing showing on it. Have tried adjusting the contrast button with no success. Any ideas please? Gill
I would open the unit and see if a cable to the display has fallen off.
You have not mentioned if unit is operating except for that.
If totally inopperative, check power supply to the unit. The display can illuminate well below the operating voltage for the synth.
Apr 30, 2010 • Music
My mg 100 hdfx halfstack was playing at half volume then lost its volume
Have the output transistors checked. That can be a source of failure. This is something you can do yourself if you have electronics experience. If you take it to a tech they should be able to pinpoint the problem by troubleshooting the amp.
2helpful
DGX620 blank blue screen and "hum" when I turn it on
Try the contrast control. My DGX505 suddenly had a blank blue screen, I found that mygrand daughter had been fiddling with knobs and switches and discovered one I hadn'y noticed. On the 505 ot is located on the rear panel right next to the USB port. A slight tweaking of the lnob and all was restored. Heart attack avoided. And I learned something from a 4-year old.
Hope that is all it takes for you too. Good luck!
2answers
Yamaha DGX620
I need Repair manuals,Yamaha DGX 620
Thank.
Oct 06, 2008 • Music
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
