Question about Peavey (Solo) Microphone
No sound - peavey bravo 112
The amp turns on, and the tubes warm up. But no sound comes out. Replaced two of the tubes. We know the others work but what else could be the problem?
In amps with a effects loop or with power amp in, always check the IN socket. Squirt in some switch cleaner and put a jack in and out a few times (can do with power off. I Have a had a few amps over the years where the signal from the pre to power amp is broken by a dodgy connection. I have had a few amps over the years with this problem
Posted on Jun 22, 2009
  • 24 Answers
I'm assuming that no sound applies to both the clean and ultra modes. You didn't say which tubes you replaced but I'm guessing the input tube was not replaced. Did you keep the old tubes? When "no sound comes out", do you hear any kind of a low level hum on the speaker output? I think the front end tube is open or the switch logic switch is defective. Hope this helps.
Posted on Nov 11, 2006
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
I have a Peavey MAX 112 Bass Combo amp. When I turn on the amp and have it plugged into the cord and bass, it immediately begins emitting a "whump whump" sound similar to the sound a beating...
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Apr 22, 2011 | Peavey Electronics Peavey Max 112 Bass...
I have a Peavey Bandit 112 amp that takes between five and ten minutes to warm up. It use to come on right away. any suggestions?
Take it for repair immediately as there is something that is thermally sensitive and it may cause worse damage with continued use. The problem is LIKELY a broken solder joint. Depending on where it is, it could cause damage to the power amp portion. It OFTEN is at one of the leads to a volume control and those USUALLY don't cause damage, but one can't be sure till it is repaired. These broken joints oxidize and then eventually warm and punch through and the device starts working. You MIGHT want to try wiggling the controls to see if one brings the unit on immediately showing itself as the culprit.
Apr 02, 2011 | Peavey Bandit 112 Guitar Amplifier With...
I have a Peavey ValveKing 112. It seems like it just takes forever for the tubes to warm up. For like the first hour that it's turned on the clean channel seems fine, but the second channel doesn't work....
Buy ONE new 12AX7 and try it in location V1 and if it doesn't help, try it in V2. This tube has TWO heaters in it and if one is intermittent that could cause your problem. The vibration MIGHT be "fixing" a briken heater after some time.
There are MANY components that could cause this, so you might have to take it in for repair if it isn't a simple tube problem. Since it works on the clean channel, V3 should be OK.
Feb 11, 2011 | Peavey Valveking 112 - Tube Guitar...
Peavey Bravo 112 hums and has less poast gain volume
Try checking to make sure that all the tubes are properly seated in the tube sockets and that one wasn't broken at the base. Considering that you just bought it you should be able to take it back and have it serviced for free.
Jul 19, 2009 | Orange Crush 30R Reverb Guitar Amplifier
389 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
