Question about HP Office Equipment & Supplies
I recieved a HP 2410 photosmart all in one used machine. How do I remove the old ink cartridges to insert new ones??? lease help!!!!!
  • HP Master
  • 685 Answers
Http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=uk&dlc=en&product=303753& here is a sight to help you
Posted on Nov 12, 2008
Insert ink cartridges? how to
Easy, you open the cover, remove the old one, remember which way it was inserted if you are not very technical, and insert a new one same way. Just make sure you hear a click, when it fully inserted.
Good luck
Oct 16, 2014 | HP Photosmart 5520 e-All-in-One -...
Print cartridge in right stall not supported for hp 2410
Print cartridge is a knock off. Cartridges have printed circuits in them that the printer can recognize as being the original replacement. This is to keep people from using other products in their printer, which I think is foul, since you paid for the printer and it technically belongs to you. Sometime HP will make cartridges with faulty circuits that the printer will not recognize.. If that is the case call them and demand a new ink cartridge.
Dec 12, 2017 | HP PhotoSmart C4180 All-in-One Color...
Hp 2410 psc all in one has all lights blinking does this indicate that I neeed new cartridge It tells me to remove the right cartridge and then replace it
yes maybe it require to replace the cartridge, but before doing it pls insert the cartridge one by one, i mean put the black ink then observe if the light stop blinking,if yes then the color ink need to replace
Oct 27, 2011 | HP PSC 2410 All-In-One InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Bought used HP 2410 from Amazon. Unit is displaying print cartridge problem on far right cartridge. Unit came with ink cartridges installed and I notice ink has spilled. I performed a detailed cleanup but...
Remove the right cartridge and check if the spring on the right came loose. When it pops out of position it tears a hole in the ribbon cable at the back of the holder and then you need a new printer. If you can find a carriage assembly it's over $200.00.
Nov 25, 2009 | HP Photosmart 2410 All-In-One InkJet...
Printer shows remove and check print...
maybe it suffered loss connection between the printer and the printhead just try to clean it..with alcohol..or maybe you print cartridge has in it's low ink state..
May 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hp psc 2410 photosmart printer is printing faintly and only bottom half of words in paragraphs. The color is also faint. I have replaced both the color and black cartridges. I have also run head cleand and...
Try taking out the cartridges and blot the bottom of the cartridge with paper towel wetted with warm water.Repeat several times.While the cartdigdes are out, use the eraser end of a pencil and gently clean the contacts in the carriage and then clean the contacts of the ink cartridges.
Feb 01, 2009 | HP Photosmart 2410 All-In-One InkJet...
Hp psc 2410 all-in-one
If I had it, and i was sure that I was using known good correct 56,57 or,58 HP cartridges in the correct slot to suit and cartridge contact membrane on back of cartridge slot was clean and I still found that the HP refused to accept them, then first I would check for a common fault....
Remove both cartridges have a really close look at the bent metal spring wire that sits in both slots, it is hooked on the right hand side of each compartment by plastic tabs and s shaped bend in the wire. I've seen these break at the tabs and then when cart is inserted they put a break in the contact membrane in the back of each slot. - replace carriage assembly
Wow that was hard to explain...anyway what is left is the possibility of a broken ribbon head carriage cable (make sure it is plugged in fully if brave enough to rip apart or it may be creased torn etc, or it could be a board fault, too expensive too fix. So I would send it to heavon..
You could try ebay or something to try to find a old model that suits your new hp cartridges.....
Nov 12, 2007 | HP PSC 2410 All-In-One InkJet Printer
Not printing text
with a wet paper clean up the head of the cartridge, and let some tint go to the napkin, or paper :) Resulted for me
Dec 21, 2006 | HP PSC 2410 All-In-One InkJet Printer
20 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
