Question about Mitsubishi WS-65613 65" Rear Projection HDTV
HELP ME ON MY WS-65613
How do you take the box out on my WS-65613 with the 4 capitors in it....do it just slide out ? i see a bracket on top. THANKS FOR YOU HELP IN ADVANCE....
The whole bottom tray will slide out. Remove the single black headed screw from the middle edge of the tray. There is a plastic lock on each side of the tray. Pull the plastic lock tab up and slide tray out. Remove all wiring from those little plastic twisty thingy's. Once the tray starts to slide, you will see which plugs have to be unplugged. Just pull the tray out about half way. OK. Now the box. Unplug the two plugs from the top. There are two small screws on one end of the box (closes to you) and a screw on each side. Remove all four of them. The metal box will pull up and off the circuit board. Be very very careful. Take your time. Try to hold down the board while wiggling the box and lifting up. There are 80 or so small pins under this box. You do not want to mess them up. Once you have the box out, remove the two screws on the top and the board with he caps will slide out. When you install the box back on the board, make sure you have the pins lined up before pushing it down on the circuit board. You only screw up once. Soory i'm not good a step by step directions. hope this all helps. I did my own about three month ago. Had new caps soldiered on for 35.00 at a electrical shop. Good luck. Jim.
Posted on Nov 13, 2008
How do I add ANT-A to the list of devices on my Mitsubishi WS-65613?
you need to have a strong enough signal present before they can be added. connect your antenna or your set top box. then check
Dec 24, 2014 | Mitsubishi WS-65613 65" Rear Projection...
Hello, my name is Tom. We have a mitsubishi ws-65613 and of course I have the green blinking light and nothing else happening. Tried to reset, unplug etc. Is it worth messing with or should I just bite...
The tv mitsubishi ws-65613 the DLP tv is big bulky and heavy.Many power issues problems and convergence problems over and over again.Buy a 46" LCD tv Samsung have great apps,friendly and a great picture.The priced is very fair too.
Oct 28, 2010 | Televison & Video
Mitsubishi tv ws65613 and remote wont work
You could try a replacement remote from www.Remotes.com
You will need an original or the replacement to access some of the features of your television
I hope that this helps.
asnowman
Oct 12, 2009 | Mitsubishi WS-65613 65" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
WS 65613 MITSUBISHI
your problem is in the power supply.check the regulator
Nov 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Upgrades
No you cant, are you having problems?
Jan 08, 2008 | Mitsubishi WS-65613 65" Rear Projection...
You will not need SAMS on this one,Frank! I fixed four Mits. with
your symptom in the last two weeks.....parts = 1000mf/25v caps
105 degree hi-temp X 4.......Location = DM module...for pix's...
www.Chris@ChrisAndNat.com.....download copy..........
I have improved above procedure....When finished with repair of
PCB.,I place it secure in sockets , with two screws on end of
module back in place.THEN I slide cover down over module
and put the side screws in..........
Be gentle and if you need more help............T.
Nov 25, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-65613 65" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
