Question about LG DLE2532W Electric Dryer
Dle5977w dryer blows 30 amp circuit breaker
My dryer blows 30 amp double pole circuit breaker when dryer is set to Normal, Towels or Heavy duty. At lower settings the dryer runs without tripping circuit breaker.
  • charles_harr Nov 15, 2008
    the dryer has preset tempuratures (
  • 4,889 Answers
I had this problem with my heater a few days ago. Turning it on blows the circuit breaker. After checking all possibilities.. I found the culprit to be the heating element! It was badly oxidized and hence ripping more power from the mains. I replaced it and its working fine. There is a high possibility that this the problem in your case too.. Try it and let me know.
Regards,
Sai.
Posted on Nov 16, 2008
    Brigadier General:
  • 6,966 Answers
Initially, to my understanding, there would only be two (2) major components that could possibly cause an overcurrent:
  • heater; and/or
  • motor.
Let's try elimination: Assuming that it would be the heater but since the heater would more often go open than short, the possibility then is greatly reduced. That would leave us with the related components to the heater which may include the thermostat and or the thermal fuse. But then again, both would most likely go open rather than short, so would again be eliminated. Having eliminated the components, then the likelihood of their wirings greatly increases. Perhaps it may be required to strip the unit and checked the wirings, connectors and terminals. Most probably a frayed wire in contact with another.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 14, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
  • 734 Answers
Please Explain more about your question
  • futureloginn
    futureloginn Dec 13, 2008
    there is a loose connection either in the breaker box or the outlet. As the machine runs, the wires warm up. If there is a loose connection, then the connection expands as it warms up, and then the current draw increases. Check all of the connections, and maybe even replace the outlet or breaker itself. :)
    Thanks for giving me FixYa.
    Just ask any question related to your problem.
    Thanks
My Frigidaire affinity dryer model AEQ6000ES2 will not start there are no error messages it just will not start. Please help.
You didn't mention if you knew for sure if there was power to the dryer or not. If a gas type, it should have a standard 120 volt outlet that you can plug a lamp, radio, etc. to see if power is present. If an electric type, it will have a 240 volt outlet specifically for a dryer. You will not be able to test the outlet unless you have a meter, test light etc.
Locate the electrical panel in the home or building for your space. If you have a gas dryer, look for single pole 15 or 20 circuit breaker that is off or tripped. If an electric dryer, look for a double pole (double-wide) 30 amp circuit breaker that is off or tripped. regardless if a single pole or double pole, if found off, push the handle back to on. If tripped, push the handle to off, then to on. Check the dryer to see if it runs.
Lastly, some of the newer appliances have mini-computers or processors in them. Like you home computer - it may encounter an issue and gets stuck. You should locate the circuit breaker for the appliance in the electric panel and shut it off for 30 - 60 seconds. Then turn back on. This is similar to a "reboot" and may get the dryer working again for you.
Nov 20, 2014 | Dryers
Can 40mp dryer and 40 mp range be computable
Hi - I'm an electrician an would like to help you with your question.
But - Umm.. huh?
By "40mp" Do you mean 40 amp? They are both "computable" but I suspect that you meant compatible. If so, yes, 40 amps is 40 amps regardless of what it supplys, as long as the wire is the right type and size. I haven't seen a 40 amp residential dryer though. Residential electric ranges and electric dryers are both 240 volts - but the dryer is usually a 30 amp circuit (#10 copper) and protected by a double pole 30 amp circuit breaker. The range is a 40 amp circuit (#6 aluminum) and protected by a double pole 40 amp circuit breaker.
If this doesn't answer your question, please explain in greater detail.
Feb 07, 2013 | Connecticut Electric Electrical Supplies
My general electric heavy duty automatic electric dryer won't heat. Is there anything to try before replacing heater?
go to your fuse box and try replacing the 2 fuses for the dryer circuit or if you have a circuit breaker box shut off the breaker for the dryer and turn it back on and try the dryer again. I used to be an electrician and found double pole circuit breakers that have only one side tripped. alot of 220volt electric dryers use one circuit for the tumbler motor and the other circuit for the heating element
May 07, 2012 | GE Dryers
What to do if 30 amp fuse keeps blowing in main breaker box
A 30 amp circuit breaker or fuse is NOT a typical size used for the protection of convenience outlets & general lighting circuits, especially in a residential setting. In fact the National Electrical Code (NEC) prohibits anything larger than a 20 amp breaker to protect a #12 copper wire and and a 15 amp breaker to protect a #14 copper wire. These are the size wires used to supply nearly all outlet and lighting loads in a residence.
It's not clear to me from your question if this 30 amp breaker is a double pole type that is providing power to a second, smaller circuit breaker panel and these outlets are fed from it. This would be in line with what the NEC would allow and what I suspect is the situation. I'm only going to get into this a minimal amount as more information is needed for me to be able talk intelligently about it.
I would shut off the loads that are connected to the 30 amp breaker. If that is a panel, I would shut off all the circuit breakers in it, then turn onn the 30 amp breaker. If it trips, then there is a problem between the 30 amp breaker and the panel. You may have connected line cables to ground or neutral - and vice-versa.
Can you please explain in as much detail as possible what is connected to the 30 amp breaker? Is it a single pole (120 volts) or double pole (240 volts) circuit? What size wires are connect to the breaker terminal(s) What type of cable is connected to it? How many wires are in the cable assembly or pipes? What is the size of wires? If they feeds a second, smaller breaker panel, where do the wires terminate - into lugs on the top or bottom of the panel or terminals of a circuit breaker? What happened or changed to cause this circuit breaker to start tripping? Is this part of a new installation - and if so, was the wiring done by an electrician? Was the work inspected?
Please try to answer as many questions as possible. The more information you can provide will help me get you the best answer.
Jan 19, 2012 | Electric Hammering
Does this Maytag Bravos electric dryer require more power? I.e., new dryer blows circuit breaker multiple times during a load. Have used electric dryers on this circuit for many years and have not had this...
Assuming that your house is wired correctly, if the plug will physically fit into the outlet, then the outlet is capable of driving the appliance properly. A breaker for a dryer should be rated at 30 amperes. The breaker itself could be going bad (they tend to fail to the off position).
Your best bet is to actually use an amp meter to measure the current it draws.
If you discover that someone wired your dryer with a 2 pole 20 amp breaker, then make sure the wire itself is 10 AWG before replacing it with a 2 pole 30.
:o)
Jun 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a Maytag dryer model MED5740TQ0 that won't start. Dryer was recently moved to a new location. House was being remodeled so plug and breaker had to be installed. Plug is a 3 prong and dryer had 4...
If you are only getting 120v to the dryer, you still have a breaker tripped. It should be right next to the single pole 30. It takes 2 breakers to get the 240v you need to run the dryer. Try resetting another breaker expecially the ones marked 30amp. You do need to get a double pole breaker installed even for safety reasons.
Apr 12, 2011 | Maytag PYE2300AY Electric Dryer
My double pole 30 amp sqaure D breaker gets a little warm...
There is loose connection somewhere.Might want to look at the wires coming to the panel.
Mar 15, 2009 | Square QO 30 Amp Double Pole Circuit...
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Lights come on and makes a clicking sound when I push start.
Try checking your fuse box or circuit breaker panel first.The dryer requires 2-30 amp fuses to operate normally...replace both fuses instead of gussing which 1 is bad. OR, the dryer uses a double pole 30 amp circuit breaker...Flip it to OFF then back to ON. Then try your dryer and if it works you can send me flowers...just kidding! If it doesn't work, write me back and we will do some more soul searching.
Thank you for contacting us at FIXYA.com
Dave, (Illeagle)
May 28, 2008 | Whirlpool GEW9250 Electric Dryer
LG DRYER MODLE DLE0332W
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
May 25, 2008 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
42 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
