Question about Cyberhome CH-LDV 700B Portable DVD Player
Reads disc then stops and reads again, keeps repeating this process
I have the Portable DVD Player and am having trouble getting it to work. I insert a DVD and it says "Reading" then stops and after a couple of seconds it says "Reading" again then stops. This process just keeps going and I am not able to play a DVD. I have tried several different DVD's and tried cleaning the DVD's to no avail. Any suggestions on how to resolve this issue? It was a prize through a company program so I don't have information on where it was purchased. It did work the first few times I tried it out but then starting the problem.
  • Gioiamia Nov 06, 2007
    Play , doesn't play, I fixed it once, but don't remember how. i want it repaired. Can you help
  • tigerfire Nov 06, 2007
    Having same problem. This worked on two occassions, but that's it. Do you know if the company will rectify this issue. The store warranty is expired. If so how do I contact this company?
    Novelist:
    Scholar:
  • 84 Answers
Hi dangraham.....I'm not very confident whether this will remedy your particular issue, however, please click on the URL below for the information....good luck my friend http://www.fixya.com/support/t178169-sound_but_no_picture_play_certain_dvds
Posted on Aug 03, 2007
My Dvd Player does not read disc when they are
first, try using rubbing alcohol and cotton swab and clean the glass laser lens eye.
If cleaning the lens doesn't work, then the lens control circuit will need to be replaced
Jul 09, 2009 | Televison & Video
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
WILL NOT PLAY A DISC
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Advent car dvd player does not read every dvd disc
you could try getting a lens cleaning disc and run that in the dvd player,could be a little dust on the lens that reads the disc.
Oct 11, 2017 | Acer EX5620-6A2G16Mi VB withXP Pro...
Says no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Jan 31, 2009 | Mintek MDP-1815 Portable DVD Player
Dynex DVD player keeps saying no disc.
unplug tape - like connection at laser - eye & replug it. Disassemble first. IT WORKED FOR ME !!!!!!!!!
Nov 30, 2008 | Dynex DX-PDVD7 Portable DVD Player
No disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Nov 23, 2008 | Curtis DVD8017 Portable DVD Player
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
Cyberhome CH-LDV 700B Portable DVD Player Logo
170 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
